went dead
Old Oct 2, 2008 | 01:56 PM
ron36535's Avatar
ron36535 is an unknown quantity at this point
Default went dead
coming to work today, my blazer just went dead going down the road. no warning or problems to let me know it would happen. the fuel pump is working, I can hear it when I turn the key. it is also not throwing any codes. engine turns but sounds like to fire is there.
please help, my baby is left on the side of the road !!
thanks
Old Oct 2, 2008 | 06:40 PM
Kage0113's Avatar
Kage0113 is an unknown quantity at this point
Default RE: went dead
The first thing I'd check would be the battery. When mine was going dead, i could turn the key to the acc. position and on position and all the lights and stuff would work, but when i tried to start it, it wouldn't go. Also, when my battery was dying, the battery would start to die if I was at a stop light and didn't rev it a little. Might be a little different in your case cause yours at least turns. I don't know why the check engine light wouldn't come on if there wasn't something wrong within the engine. My girlfriends jimmy died in the middle of the road when her alternator died. So I'd check your electrical stuff first. Just my opinion.
Old Oct 4, 2008 | 09:46 PM
ron36535's Avatar
Well I checked the ingnition module under the cap, and it was good, then replaced the coil, no change. I would love to here someones thoughts on the matter
Old Oct 5, 2008 | 08:56 AM
Back to the basics. If you use starter fluid through the throttle body, will it start? If so, then you know you have air and spark, but not fuel.
Old Oct 5, 2008 | 04:36 PM
chizgod's Avatar
chizgod is an unknown quantity at this point
sounds like what happen to mine recently check ecm fuse
Old Oct 7, 2008 | 10:12 AM
parttimer's Avatar
parttimer is an unknown quantity at this point
I currently have the same issue! I dida separate post though, didn't see this one. Mine died on the way to work, but later that day it was fine. Seems like an intermittent problem for me.
dhud64
Jan 11, 2015 05:27 PM
TAZ454
Jul 17, 2014 08:26 PM
94s10blazin
Aug 10, 2013 01:00 PM
Logan
Dec 3, 2009 12:11 AM
rriddle3
Aug 26, 2007 04:38 PM
