What is the "C" on the distributor cap and where does the plug wire go?
Old Jun 26, 2010 | 08:36 PM
jstein's Avatar
jstein is an unknown quantity at this point
Default What is the "C" on the distributor cap and where does the plug wire go?
Hey guys,
I'm hoping you can help me answer this relatively easy question. I am in the midst of performing a tune up. I just got finished replacing the distributor cap and rotor. I was rushing to beat the rain and in my haste I did not take note of the location of the plug wire that goes in the "C" port. I got all of the other wires connected yet I can't seem to locate this one. I feel foolish even asking this, but where does this wire originate so I can trace it? It is probably worth noting I am reusing the old wires. I checked the resistance and they all are fine. Why replace them if they are still working right? Anyway, I even crawled under the car thinking the end dropped and was hanging out of eye sight but I didn't see anything. Any help would be most appreciated!
Old Jun 26, 2010 | 09:10 PM
Ck1500's Avatar
Ck1500 is on a distinguished road
Originally Posted by jstein
Hey guys,
normally the C stands for Coil... as in the shortest plug wire to the Ignition coil, which is located close to the distributor...
hope this helps
Ck1500
Old Jun 26, 2010 | 09:24 PM
jstein's Avatar
hope this helps
Ck1500
If I understand this correctly it is basically linking this:
to this (the port on the lower right)
Old Jun 27, 2010 | 07:52 AM
jstein's Avatar
I have been working on cars my whole life and consider myself rather knowledgeable. This is my first go at distributor cap and rotor replacement. As I explained, I was under tight time constraints to beat the weather so labeling the wires slipped my mind.
So, now that that's out of the way. Does someone else have the answer to my question?
Last edited by TripleBlackBlazer; Jun 27, 2010 at 03:47 PM. Reason: Removed rude and insulting quote
Old Jun 27, 2010 | 08:27 AM
cage47's Avatar
cage47 is on a distinguished road
Uh, it WAS answered.
Old Jun 27, 2010 | 10:38 AM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Don't know if different years have the coil located in different places but on mine the coil is on top of the pass side valve cover.
futuredoc
Oct 7, 2024 06:14 PM
red1127
21
Sep 8, 2018 05:03 PM
joejiz
Aug 1, 2014 07:33 PM
lcars
14
Dec 10, 2007 03:02 AM
boulonman
Mar 5, 2007 05:10 AM
