what can cause a timing retard??
Old Oct 22, 2012 | 06:58 PM
"If you can't get cam retard to spec, you can remove the OEM hold down bracket and install one of these: Mr Gasket Part No. 1009 - Distributor Clamps"
This will make the distributor fully adjustable.
Old Oct 22, 2012 | 08:25 PM
coolasice's Avatar
coolasice will become famous soon enough
you can also take a dremel to the hold down bracket to widen the gap a bit giving you more rotation.
nalgman's Avatar
nalgman is on a distinguished road
yeah. i was thinking' something like that when i realized that the bracket was not moving..
i have an old bracket from a 350 engine..
is there a trick to pull the bracket from the distributor?
the other thing that you sayd in the past reply.. that the timing chain may be stretched... so that's equal to $$...
i'll try to do by now the Bracket thing to stay close to Zero...
thanks again Captain
Old Oct 22, 2012 | 08:51 PM
No real trick to remove the bracket... Put the distributor in a vice, open the bracket slightly to slide it off. Your SBC distributor hold down will work in place of the one in the link I posted. Just be careful when removing the distributor. I usually bump the starter until the rotor points to the "6" on the distributor housing, then pull it out. Then install it so the rotor points to the "6".
billfrank85
May 11, 2012 05:03 AM
mritech
Feb 12, 2011 10:38 AM
ded2klf
Nov 29, 2010 10:15 PM
ExplicitYourSelf
Jun 16, 2009 09:19 PM
phantom
Aug 14, 2007 07:38 AM
