What is my next step?
Old Jul 23, 2012 | 05:33 PM
sdaringer's Avatar
sdaringer is on a distinguished road
Question What is my next step?
98 Blazer 4.3L
Intake Gasket was replaced after leaking coolant. Good news, no leaks. Bad news, P0303.
Have changed plugs, wires, cap & rotor, pcv valve and a vacuum hose I found a hole in, cleaned EGR and replaced gasket. Still have the misfire, and only on #3.
What should be my next step? A friend suggested compression test, but the plugs removed were not fouled with oil. A little dark, but not wet.
Thanks for any feedback.
Old Jul 23, 2012 | 07:50 PM
Joshua1023's Avatar
Joshua1023 is on a distinguished road
Is it running rough? Any noticeable difference in idle when you pull number 3 wire?
Old Jul 24, 2012 | 04:22 AM
sdaringer's Avatar
Nothing noticable. Runs rough either way.
Old Jul 24, 2012 | 06:07 AM
Joshua1023's Avatar
Do you actually have a spark at number three? Did you change the plugs yourself? The only reason I ask is that number three is a bear to get to sometimes and someone may have skipped it, snapped it, or left it a little loose.
Old Jul 24, 2012 | 07:15 PM
sdaringer's Avatar
Did it myself, and yes it was a pain to get to. I'm sure it's in there straight and snug. Called on all my patience to do it right!
Was talking with a guy at work last night about this...is it possible that the distributor could be off a tooth after putting it back together after the gasket replacement?
Old Jul 25, 2012 | 09:40 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
If it was, it there would be a problem with every cylinder, not just #3 I would think.
NCRD1331
May 9, 2013 08:31 AM
chevyblazer9588
Nov 20, 2012 10:40 PM
poertsch
May 3, 2012 06:12 PM
rudd21
Nov 12, 2011 03:49 PM
toaks
Detailing
Aug 26, 2008 11:44 AM
