What sensor is this? -pic
Old Jan 11, 2009 | 03:33 PM
nonstop's Avatar
nonstop is an unknown quantity at this point
Default What sensor is this? -pic
What sensor is this? and why would the truck run with out it?
some background, just had a guy put in a junk yard 4.3 because the orginal was blown. I have an oil leak and in the search for the leak found this sensor just sitting on the distributor....
any ideas, Thanks, Steve
[IMG]local://upfiles/13276/E2CC672B16514B80A6528EEA306F8503.jpg[/IMG]
Old Jan 11, 2009 | 03:38 PM
nonstop's Avatar
Default RE: What sensor is this? -pic
Old Jan 11, 2009 | 03:51 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
oops...that goes into the back of the block behind the distributor. It'll be a pain to get to with the distributor installed. I'm not sure what the sensor is but it goes behind and below the distributor on the upper drivers side of the block right behind an oil pressure sensor.
Old Jan 11, 2009 | 03:55 PM
nonstop's Avatar
Cool...i'm thinking it's the knock sensor...because i searched "knock sensor" and it's in the same location you described.
Would oil leak out of the hole the sensor is suppose to be??? Is the distributor easy to remove?
Old Jan 11, 2009 | 07:30 PM
Knock sensor.
No, oil will not leak out of the hole. It is just a blind hole drilled into the block.
About the distributor, if you mark the position of the rotor before you lift and its final position after you have lifted it out, it is not all that difficult. Get it off by a tooth and try to start the truck and you will have some fun!
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
