what should my idle be ??
850 +/- 50rpm depending on conditions (is the truck warm? how warm? etc.).
Set by screwing curb idle bolt out, then back in until the IAC takes over. Do this with a warm motor.
Do not use the curb idle adjustment to set the idle.
Josh <><
Josh <><
Hello,
That sounds a bit low. Pull the IAC and make sure it's not gummed up. Do NOT try to move the pintle (pointed thing) as it will ruin the part.
Take some carb cleaner and clean it (excepting any rubber parts) and clean out the hole it fits into.
You might also check to see if your EGR valve is functioning properly.
Josh <><
Josh <><
ncpatsfan
Jul 15, 2012 05:05 AM
97BLAZE4X4
Feb 7, 2010 07:33 PM
