what is this thing?
Old Aug 7, 2008 | 10:02 AM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
Default what is this thing?
I just don't know what the big thing in the rear bumper of my 97 blazer is and what it does/there for. It is on the driver's side directly under the fuel filler door. It is about 12" long 5" tall and 3-4" wide. It is plastic and has fuel hoses going to and from it, two small and one about an inch in diameter. It is mounted at the very bottom of the quarter panel and is basically hidden behind the driver's side plastic rear bumper cover.
Sorry if this sounds confusing. I just didn't have a chance to take a picture of it yet. Any help is greatly appreciated.
Old Aug 7, 2008 | 10:07 AM
Default RE: what is this thing?
It is the Evaporative Emission System charcoal canister. It is used to capture fuel vapors that expand out of the tank while the truck is off. While the engine is running, periodically the canister gets purged into the engine, removing previously trapped fuel vapor.
Old Aug 7, 2008 | 05:55 PM
KA3AX's Avatar
so is there any way I can get rid of it? will it do any harm? Also, I don't recall seeing this sort of thing on other cars I've worked on.
Thanks swartlkk very much for the helpful info!
Old Aug 7, 2008 | 06:41 PM
Gotta ask what is the motivation for removal? The evap system would not work properly without it.
Old Aug 7, 2008 | 08:25 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Yah in most states it would fail smog test without it if I recall. It doesnt weigh hardly anything, and is only an issues when it leaks really.
Old Aug 8, 2008 | 10:30 AM
KA3AX's Avatar
Just don't see a point in it, if most cars don't have it, why does this one have to have it? What kind of problems might arise if I remove it?
Old Aug 8, 2008 | 10:32 AM
Actually, most cars do have it. You just don't see it.
Old Aug 8, 2008 | 09:29 PM
portcqb's Avatar
Yah like the same identical unit is on like all gm trucks, vans, and suvs. They are easiest to see on the vans. Cars are so crammed its most likely hidden somewhere like everything else in cars.
gcookman
Mar 26, 2009 09:58 AM
Canadian88
Nitrous, Super Chargers, & Turbos
15
Feb 27, 2007 02:34 AM
nslide10
Nov 24, 2005 02:52 PM
ivannj
Nov 22, 2005 04:39 PM
Hanr3
Sep 21, 2005 05:05 PM
