What would be considered a "tune up" these days.
Old Sep 4, 2013 | 03:35 PM
williamapocalypse's Avatar
williamapocalypse is on a distinguished road
Default What would be considered a "tune up" these days.
Think i have had a misfire that tripped the service engine light. I figured I would do and entire "tune up". I'm at around 130,000 miles with no real issues so far. Anyone have a list of the most common practices ie, plugs, oil, etc.? Sorry for the noob question. Thanks for your time.
Old Sep 4, 2013 | 05:52 PM
KM346's Avatar
KM346 will become famous soon enough
Plugs, wires, cap, rotor, fuel filter... air cleaner if it needs one. Maybe clean the TB / MAF and run some seafoam through if you're feeling adventurous.
Old Sep 4, 2013 | 08:37 PM
burned's Avatar
burned is on a distinguished road
Depends on the service life of the vehicle, but I would also look at more than just a tune up. Has the other fluids been changed? Brake fluid, power steering, front and rear diffs, coolant, belt, hoses...etc.
Old Sep 5, 2013 | 02:06 PM
Thanks km346. Not in the two years I've had it Burned...I've only replaced the belt, changed the oil last year...replaced a few minor parts and engine components. Rear brakes. I have the tools and the factory manuals...but I always run shorton time. Thanks for the replies.
Old Sep 5, 2013 | 02:30 PM
jimspahr@msn.com's Avatar
When you say you tripped the SEL, what exactly did you get? That would be helpful. I like KM346 list but you might add O2 sensors to the list, if it hasn't been changed recently. Also I would add to the list AC Delco or Delphi for the plugs, wires, dist. cap and rotor, etc.
Old Sep 5, 2013 | 06:30 PM
AJBert's Avatar
Find out why the SES light is on. A tune up is always good but may not clear up code(s) that are set.
Old Sep 5, 2013 | 07:43 PM
Weird thing is the check engine light turned back off after being on for four days. I ordered an obd2 bluetooth dongle to check the code but the lights off. Will the code still show?
Old Sep 6, 2013 | 12:55 AM
richphotos's Avatar
The code should still be stored I think...??
Old Sep 7, 2013 | 10:15 PM
Well it wasn't a misfire. P0147. O2 sensor after the cat. The exhaust is crap. I was meaning to replace it all. Guess now is a good time. Thanks for all the replies though. I will aim to do a tune up this fall.
l008com
Aug 26, 2014 05:12 PM
Lanqe
Apr 30, 2012 10:10 PM
bgonzo
Jul 18, 2011 04:22 PM
W2JGA
Dec 15, 2009 07:18 AM
