What years interchange for PCM?
Old Nov 29, 2009 | 08:39 AM
dootch's Avatar
dootch is an unknown quantity at this point
Default What years interchange for PCM?
I have a 97 Blazer that i think is giving me the P0785 Shift Timing Solenoid code and i've changed the Solenoids, Ignition switch, Trans filter so now i'm going to change the PCM and just wondering what years etc. will interchange as i no 98 is different. Any help would be great Thanks
Old Nov 29, 2009 | 09:19 AM
96-97. You can make a 98 thru mid-02 PCM work if you get it reprogrammed.
Make sure the RPO codes match as much as possible.
Old Nov 29, 2009 | 10:52 AM
dootch's Avatar
Thanks Swart maybe i should have specified S10 Blazer? if that makes a difference not to sure and the computer that i picked up from a 98 has only 4 connectors and my 97 has 5 (small middle connector not on the 98.
Old Nov 29, 2009 | 02:47 PM
Ah yes, Sorry. No difference in the S10 considering that there is no S10 moniker on the s-series blazer after '94. I just did not remember the connector differences. One could rewire if they were interested enough, but suffice to say that you should stick with the 96-97 PCMs.
lonzig
Dec 15, 2010 09:22 PM
kjmitchell
Jun 18, 2010 12:39 AM
MNHawk
Dec 21, 2006 09:38 PM
MIKE82
Nov 15, 2006 02:16 AM
ginobass
Sep 11, 2006 05:16 PM
