wheel hubs
Old Sep 9, 2012 | 05:45 PM
bsuding's Avatar
bsuding is on a distinguished road
Default wheel hubs
can someone tell me if it would be okay to put 2wd front hubs on my 4wd 98 4dr blazer?
Old Sep 9, 2012 | 06:30 PM
warthogdriver's Avatar
gut says no..... and judging by the different part numbers per application i would say no.
Old Sep 12, 2012 | 11:08 AM
bsuding's Avatar
The front diff exploded out when the chain started catching the case, so I was entertaining the idea of converting to 2wd but I was concerned that when I pulled the front diff I would have to pull the cv's or the'd just be hanging loose, and I didn't know if I needed the cv's for steering or suspension or to hold the wheel hub in the wheel. thanks for the advice, I really appreciate it.
Old Sep 12, 2012 | 11:11 PM
abig84's Avatar
usually what people do is actually remove the cv joint, but keep the end part that goes into your bearing. so basically just break or cut the cv joint at the joint part right behind the wheel, put it back into your bearing and re-tighten the nut. instant 2wd.
Old Sep 13, 2012 | 10:47 AM
Hank's Avatar
Hank is on a distinguished road
I did remove the front driveshaft from a Gand Cherokee, worked well for me, 8 bolts that's it!
Don't know if chev does the same?
grz Hank.
Nicko44
Jun 8, 2013 07:27 AM
lizardking88mph
19
Jan 3, 2012 07:32 PM
mcblaze
Oct 21, 2009 03:32 PM
Cavalier z24
Mar 6, 2009 11:29 AM
mont1340
Feb 11, 2006 10:37 PM
