Where is the AC Drain
Old Aug 12, 2011 | 06:58 PM
Theejonnyboy's Avatar
Theejonnyboy is on a distinguished road
Default Where is the AC Drain
Can somebody tell me where the AC drain is on 2000 blazer LT. Please if some could tell me and post a picture that would be amazing, I will even tattoo your username on my arm with a a heart around it. please and thank u
Old Aug 12, 2011 | 07:16 PM
Above the frame on the passenger side where the HVAC housing under the hood meets the firewall. It'll be the lowest point. It is best seen with the inner fender removed.
Old Aug 13, 2011 | 04:12 PM
stlwaco's Avatar
stlwaco is on a distinguished road
I looked for mine when I did my heater core. Had the inner fender out and could not find the drain anywhere on the box.
Old Aug 13, 2011 | 04:16 PM
It's there. It isn't a tube or anything, just a slot in the plastic where it meets the firewall at the lowest point of the outer HVAC box.
Old Aug 13, 2011 | 04:19 PM
stlwaco's Avatar
Think I could fab up a good drain with some vacuum hose and a nipple?
Old Aug 13, 2011 | 04:26 PM
You could, but the factory drain is in the lowest part of the system. You really don't need a nipple or vacuum hose. Just drill another small hole.
I'd concentrate on cleaning the factory spot. Once you know where to look, it isn't that difficult to find.
Old Aug 13, 2011 | 10:30 PM
streblo's Avatar
Post pics of the tattoo when you find it!
Old Aug 16, 2011 | 12:03 PM
how do i clean it, do i just i pull back the plastic and wash it out
Old Aug 16, 2011 | 12:05 PM
I used a portion of welding wire with a small hook on the end fished up through the factory hole. Some compressed air helps as well.
Old Aug 18, 2011 | 10:05 PM
coolasice's Avatar
coolasice will become famous soon enough
A picture or diagram of this would be useful, I can't seem to find it anywhere
2klt
Apr 4, 2006 11:48 PM
HCCAFan
Mar 14, 2006 06:30 PM
eng69
Feb 13, 2006 03:08 AM
FLcruising
Jul 4, 2005 02:51 PM
2001Blazer4x4
Mar 2, 2005 10:45 PM
