Why is my eater core is leaking
1997 blazer 4x4-I never got really good heat in the winter so todayI figuredI would try flushing out my heater core. And now afterI flushed it out its all of a sudden leaking in the truck. It never leaked before, so why is it leaking right afterI flushed it out?
RE: Why is my eater core is leaking
The most likely cause is that there was a blockage in the core which resulted in corrosion. The blockage was sealing the corroded heater core. When you flushed the core, you removed the blockage and now have a leak. Happens more than you would think.
Never mind it stopped now.wasent dripping coolant,was only dripping the waterI flushed it out with I'm guessing. I still dont understand why it would drip water all of a sudden then stop. Thanks for the help though!
Sounds like you optminism will be short lived.Betting the hole just got blocked again.
1994BlazerS10
19
11-21-2009 02:06 AM
ShadowHawk
23
11-12-2008 01:50 PM
Canadian_Blazer
03-17-2005 12:18 PM
