wierd noises and then fluid
Old Mar 15, 2008 | 09:40 AM
tabluvsyou's Avatar
tabluvsyou is an unknown quantity at this point
Default wierd noises and then fluid
i have a 95 blazer and i took it to the shop yesterday and they tod me that my egr valve kept opening up and my brakes have been really loose and what not. last night i was parrallel parking and when i turned my wheel a whole bunch of fluid started leaking from the bottom of my car. can anyone help? the power steering has been making really weird crying noises and my car has been driving really rough. please help!!
Old Mar 15, 2008 | 03:04 PM
rriddle3's Avatar
Default RE: wierd noises and then fluid
I could take a guess at what the fluid was, but did you happen to touch it and see what color it was or what it felt like? Have you checked the level in your power steering fluid reservoir?
Old Mar 15, 2008 | 06:04 PM
DO NOT drive the car until you identify where the fluid is coming from. I would go out on a limb and guess that it is power steering fluid due to the other symptoms you are experiencing, however, you have to confirm that. Check the res level as Rich has suggested.
As far as the EGR valve goes, this is a common issue among a wide variety of s-series years. You can remove the EGR valve, clean it, and reinstall it with a new gasket (one that has a screen on the inlet side) and the symptoms associated with this (your rough idle issue you noted in another thread), will most likely be cleared up.
Chic_Bowdrie
18
May 12, 2013 09:21 PM
latinoNJ
May 12, 2010 07:10 PM
outdoorxman
15
Jun 12, 2007 05:06 PM
Inferno
Oct 22, 2006 08:56 PM
drefda
Oct 4, 2006 05:31 PM
