Will not pull
Old 02-18-2020, 05:58 PM
Bovandy88's Avatar
Bovandy88 is on a distinguished road
Default Will not pull
Hi I have a 1999 Chevy Blazer 4.3 4x4 automatic transmission. I just got finished doing intake manifold gasket job after getting everything put back together I cranked ran good drove it for about a quarter mile then rpm was going up but not going very fast in a couple min it quit pulling all together in any gear when you shift it will not move. It was moving and shifting fine before the intake job did I forget to plug something back up and I did check the fluid and it was full. Any suggestions?
Old 02-18-2020, 06:52 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
Any codes?
George
Old 02-18-2020, 07:12 PM
Bovandy88's Avatar
Service engine light is on but I do not own a scanner
Old 02-18-2020, 07:33 PM
Bovandy88's Avatar
Part store friend is going to bring theirs tomorrow in the mean time anything you can think of. Just got in it it been setting for a few hours something will not move in any gear don't even feel it trying to shift.
Old 02-18-2020, 09:24 PM
GeorgeLG's Avatar
So the engine runs, you can move through all the gears at idle, in any gear the engine revs up but the truck will not move?
George
Old 02-19-2020, 05:26 AM
Bovandy88's Avatar
That is correct.
Old 02-19-2020, 07:27 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
Wonder if for some strange reason the shifting linkage came unhooked below @ the side of the transmission..I have seen that happen quite a few times where the parking pawl 'ball' deteriorates allowing the linkage to come off...Weird the timing though...although timing sometimes means nothing....just a thought.....have someone move the shifter and watch below to see if the arm is connected to the side of the trans....Jerry
Old 02-19-2020, 08:28 AM
GeorgeLG's Avatar
In addition to the linkage, have you checked the trans fluid level?
George
Old 02-19-2020, 08:38 AM
Bovandy88's Avatar
Checked it before I cranked it and it was showing about a half inch past hot gonna let I run and warm up and see if it goes down
Old 02-19-2020, 08:55 AM
Bovandy88's Avatar
Been running a while I checked it fluid is not moving on the dip stick still showing about a half inch past full reckon it's the pump not working
Quick Reply: Will not pull
