Will a Tahoe POSI fit in a s10?
Old Jul 26, 2020 | 06:51 PM
Any rear axle should last nearly forever with decent maintenance (considering wear only, not breakage). 300k or 400k miles is pretty common. But if you want to upgrade anyway, this is probably a good time. If you're thinking of replacing it with an 8.6" rear, I think they're getting pretty hard to find, so good luck.
Old Jul 26, 2020 | 07:24 PM
LesMyer's Avatar
Originally Posted by Tom A
It sounds like you did it right, and your pattern looks good.
Maybe you can put it on jackstands and run it to pinpoint where the noise is coming from? It helps to put the tip of a long screwdriver on the housing by each bearing, and press your ear against the handle. Obviously, you want to use extreme caution when doing that.
Yep, contact pattern looks good. Not sure what happened. What was the backlash?
Old Jul 26, 2020 | 08:06 PM
1996s10blazer's Avatar
1996s10blazer is on a distinguished road
Does anyone have a zr2 posi that they don't want? How long will a posi in a zr2 last before rebuild?
​​​​​I don't have a tool to set the backlash. I used the original shims so I figured that it should be fine since I used all the original gears.
Old Jul 27, 2020 | 08:58 AM
LesMyer's Avatar
Regarding the backlash, I just thought it would be another indicator that all is OK. With that pattern, if backlash is good - all should be fine.
Bamabreeze
Jun 15, 2020 07:12 PM
ThaGMan
Mar 20, 2018 07:24 AM
kmh13
Aug 30, 2015 10:16 AM
Brian_D
Dec 22, 2013 10:41 AM
dieselfumes
Jun 23, 2005 06:21 PM
