Will these wheels fit my blazer?
Old Aug 5, 2014 | 04:09 PM
Tajohns34's Avatar
Default Will these wheels fit my blazer?
Here are the wheels that I am thinking about buying
Camaro snowflake wheels
I know they will fit, but I can't seem to find the backspacing anywhere. The only reason that I want to get rid of my 15" camaro wheels is because I want to avoid running flares. I was just wondering if these would stick out or not.
Old Aug 5, 2014 | 07:18 PM
chris015's Avatar
If you have 4wd,they should fit. 2wd,they will stickout a poo ton.
Old Aug 6, 2014 | 09:19 AM
LannyL81's Avatar
4x4 stock wheels have around a 6.5" offset on them. I have never been able to find a wheel that has this much offset and therefore would stick-out.
I think chris015 has it backwards; if 4wd they will stick-out, 2wd they will be fine.
Old Aug 6, 2014 | 09:28 AM
chris015's Avatar
waaaaaaait. you might be right. I ran some trans am wheels on my last 4wd,they were flushed perfectly. For some reason i was thinking camaro. as far as trans am wheel spacing,im not sure if they are the same as camaro.
Old Aug 6, 2014 | 10:16 AM
LannyL81's Avatar
I should say that I was never able to find a 4wd wheel with such a high offset. Trans AM or Camaro wheels are not rated as 4wd so they may have such a high offset.
So chris015 you are probably correct after all, these Camaro wheels will fit a 4wd fine, but stick-out on a 2wd.
Not a good idea to use a non 4x4 wheel on a 4wd, but then again...most 4wd vehicles never see any off-road time and these should be fine for street driving.
Old Aug 6, 2014 | 10:37 AM
Jamaroon's Avatar
Those have 6.875" Back spacing, and are 8" wide. They will stick out 1/8" farther than stock 4x4 wheels.
They would not stick out on a 2wd, they would be too far in. 2wd trucks would need to run spacers on all corners to use these wheels
As far as non-4x4 wheels on a 4x4, unless you're rock bouncing with the damn things they'll hold up just fine.
Old Aug 7, 2014 | 06:30 AM
Tajohns34's Avatar
Thanks guys! I will be picking them up hopefully this weekend and i'll see if I can find a good deal some used tires. Then I will be selling my camaro wheels.
Alexys4530
Tires and Wheels
May 22, 2014 09:25 PM
96blazen
Tires and Wheels
May 14, 2014 05:52 PM
xJakeLIKEShisBLAZERx
Tires and Wheels
Sep 10, 2011 12:50 PM
stepjl
Tires and Wheels
Jul 17, 2010 07:32 AM
wdb4719
Tires and Wheels
Feb 7, 2008 10:16 PM
