window motor replacement
Old Aug 6, 2008 | 09:43 AM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default window motor replacement
Okay, my driver's window no longer moves...theres' no noise, it just doesnt' move. I do have power at the switch. At idle, if i hold the switch in either direction i can see the voltmeter on the dash dip a little.
It's 100$ more to buy a motor with regulator but i've been reading and it seems it's harder to change a motor without changing the regulator because you have to remove the regulator anyways and then keep it from colapsing.
What's the best thing to do? Is this a really brutal job?
Old Aug 7, 2008 | 06:58 AM
Smoked's Avatar
Default RE: window motor replacement
Turns out it was the motor. Swap was easier than I figured...just over an hour top to bottom. DcFlux's writeup is great especially for removing the door panels.
packmule75041
Jan 3, 2010 04:02 AM
GHN111
Oct 3, 2009 07:52 AM
Shaun98si
Jul 28, 2009 08:09 PM
WLB
Dec 9, 2008 08:48 AM
