Windshield Wipers all hay wire
Old Mar 26, 2007 | 10:53 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Default Windshield Wipers all hay wire
Well the problem; When i turn my wipers on the go on but the lowest setting they will stop in the middle of the window. the highest setting they go fast and dont stop even when i turn them off they keep going, If i wait like five minutes they will stop somewhere on the windshield, never the same place sometimes in the off position most of the time sticking up somewhere blocking my vision. I tired the cold soder fix and this still happens.
How do i fix this from happening and make the work correctly.
Thanks in advance
Brian
Old Mar 27, 2007 | 12:01 AM
Default RE: Windshield Wipers all hay wire
Check out the DIY article I wrote up a while back:
Fix for cold solders in the Wiper Motor
Old Mar 27, 2007 | 12:25 AM
hillbillyinOhio's Avatar
actually, if you remove the wiper arm cover there is a nut that if you tighten it up, will fix your problem.
Old Mar 27, 2007 | 09:43 AM
This all points to an electrical problem to me seeing as how they won't stop even after they are turned off. The motor is easy enough to pull the cover and check the solders, but I'm not sure you will find anything wrong inside. From the sounds of it, it may be the multifunction switch that is causing the problem, but lets start with the simple stuff first.
Old Mar 27, 2007 | 11:09 AM
blazinloud's Avatar
mine do the same thing! so I just curse at them till they stop they know who the boss is!
Old Mar 27, 2007 | 02:56 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Do swartlkk's cold solder fix FIRST.
9 out of 10 chances the problem will go away.
Old Mar 27, 2007 | 07:36 PM
99blaze's Avatar
99blaze is an unknown quantity at this point
I had the same problem with mine andeventually my wipers stopped working. I also tried the cold solder fix but it turned out to be the multifunction switch which runs about $170.
Old Mar 29, 2007 | 01:20 AM
KIllarb634's Avatar
I tried the cold solder thing as stated in the first post, It still didnt' help. any other ideas
Old Mar 29, 2007 | 01:23 AM
KIllarb634's Avatar
If it is the multi function switch, would i need to replace the whole thing or find out what is wrong with it and try to fix that
Old Apr 5, 2007 | 04:26 AM
kerander's Avatar
kerander is an unknown quantity at this point
I was having the same problem seemingly because of a low power situationwith a weakened alternator. After changingit (and doing a conditioning and full charge on my battery) theproblem went away.
shadetree74
Oct 12, 2013 10:35 PM
mudlife91@yahoo.com
Dec 7, 2012 01:24 AM
Jonas
Aug 9, 2010 06:29 PM
pjtbdcd
Nov 25, 2006 04:14 AM
scoot
Jan 11, 2005 02:38 AM
