Wipers driving me Lasso!
Old 03-15-2014, 09:00 PM
daanbc05's Avatar
daanbc05 is on a distinguished road
Default Wipers driving me Lasso!
I have a 05 4wd 4-door, when I turn on the windshield cleaner, everything works, Except wipers Never shut off! I'm forced to turn the ignition off then on again to get them to stop! If I just use the wipers alone it works fine. Any thoughts?
Old 03-16-2014, 08:44 AM
The wiper pulse board is known to have cold or loose solder joints. Some members have successfully re-soldered the joints, others need replacement. The board is attached to the wiper motor:
Old 03-16-2014, 09:33 AM
daanbc05's Avatar
Thank you. I will look into this Tuesday.
Old 03-16-2014, 08:35 PM
TDS-MN's Avatar
TDS-MN is on a distinguished road
Access to the circuit board is pretty easy, and if you are comfortable using a soldering gun, you could have it fixed in well under an hour. I think that a replacement board was around $40 thru a couple local parts stores, but I was lucky enough to only need to hit mine with the soldering gun, and mine were fixed. Had very similar symptoms as you described above.
Old 03-17-2014, 07:53 AM
daanbc05's Avatar
I have a soldering gun, I will try to fix it myself. Worst case I can't and I need to spend $40 for a new board. Or go to the local junkyard and get one for 10-15 bucks. When you opened the box, were you able to see what needed to be soldered?
Old 03-17-2014, 06:09 PM
TDS-MN's Avatar
I think there was a how-to post somewhere on the site that I had in-hand when I tackled this job. There was a diagram that pointed to the connections.
Old 03-17-2014, 06:49 PM
daanbc05's Avatar
I tried searching under wipers/ diagrams/windshield wiper, nothing comes up about this problem.
Old 03-17-2014, 07:02 PM
daanbc05's Avatar
Found it. THANKS!!!!!
Old 03-18-2014, 07:41 AM
LannyL81's Avatar
LannyL81 is on a distinguished road
Do every solder joint you can get to.
Old 03-18-2014, 03:25 PM
daanbc05's Avatar
Thumbs up
THANK YOU! To ALL. I took the board out and didn't see any cracks or undone soldering. But I re-soldered most of them. I then added a little fresh grease to. All works well. I also replaced my low pressure switch on the accumulator for the A/C. The past two weeks it's been working then stops. I hit the switch then it works again for awhile then stops. So today I just replaced the switch. $24.44 from AC DELCO on ebay shipped! I also added a little freon and checked the charge. ALL is well for now, until the next thing to fix. LOL.
Quick Reply: Wipers driving me Lasso!
