wipers not working sumtimes
somtimesthey work somtimes they dont
somtimes they cut off in the middle of working and just stop for no apparnt reason then work
help i am most died in the rain from this what is it what could i do?
mine did that same exact thing except no matter what speed you put them at they were always the same, luckily mine never seemed to cause any problems when it was raining...
i ended up having to buy that whole lever and that fixed it. i dont know how much it cost though, my dad bought it
Could be the lever, could be the solder joints in the wiper motor circuit board.
Fix for cold solders in the Wiper Motor
Over the past weekend, I would set the wipers on the lowest delay, and they would go for about one or two wipes, and then they would start going all the time, and I couldn't shut them off!! (Sounds like the reverse problem you were having!!)
After it dried out for a couple of days, they seem to be working properly again- my guess is that possibly the increased humidity did a number on the switch in the combo switch. On Rockauto, that switch is worth about $118.
I had the same issue and I just fixed it last night. Just follow the instructions through the link that the administrator set-up(thank-you by the way!) If you are mechanically inclined in the slightest bit you shouldn't have a problem- you can plainly seeon the circuit board where thesolder joints are cracked. If you getit apart and the two little flexible metal arms on the circuit board are damaged and worn bad, then you will probably need to replace the entire motor.
If the wipers won't shut off, that is typically a multifunction switch problem. Well that or you have shorted out wires in the harness somewhere. By far the most common problem is cold solders on the circuit board.
