it wont turn on!!
Old May 20, 2007 | 02:52 PM
christianelbori's Avatar
christianelbori is an unknown quantity at this point
Default it wont turn on!!
hi, i have a 1997 chevy blazer 4wd and for some reason it wont crank up. im guessing is some type of sensor but i had replaced the fuel pump, fuel filter and still the same problem. can somebody help me with this problem?
Old May 20, 2007 | 03:15 PM
Default RE: it wont turn on!!
Can you give us some more details?
When you turn the key to the start position, does the engine turn over? Or do you just hear a click? If it does turn over (starter turning the engine), but won't catch and run, then you have to verify fuel, air, and spark.
You can check for fuel pressure at the fuel rail behind the throttle body. To do this properly you should have a gauge (~$25 at the autoparts store).
Please give us some more details and we'll try to work through this with you.
Old Jan 2, 2008 | 09:17 PM
martinblazer95's Avatar
martinblazer95 is an unknown quantity at this point
my 95 blazer wont start,this morning it ran fine but when i tried this afternone there was no power what so ever to the engine.this i the 3rd time this happens to me after aabout a day or a few hours it will turn on like nothing ever happend?
Old Jan 2, 2008 | 09:38 PM
Sorell's Avatar
Sorell is an unknown quantity at this point
My old car did the same thing, it turned out to be a relay... thats a Honda though. Is there no power electrically (your lights and stuff) or is there just no way it'll turn over... all the answers to swartlkk's questions are kinda helpful to know anything regarding the actual problem.
Old Jan 3, 2008 | 11:01 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
ORIGINAL: martinblazer95
Sounds like your fuel pump is going bad. I replaced mine last summer due to the same symptoms. It's better to replace it now before it decides to cut out on you while you're driving in traffic. How many miles do you have on your vehicle?
SubbinBlazer
May 24, 2013 12:56 PM
gturzer
Mar 25, 2013 05:00 PM
ta3ff
Oct 14, 2009 05:07 PM
jetsmy
Aug 1, 2008 10:10 PM
shaka1111
Feb 13, 2006 02:23 PM
