wow it was cold today here...
Old Jan 17, 2007 | 07:30 PM
blazerxtreme1's Avatar
blazerxtreme1 is an unknown quantity at this point
Default wow it was cold today here...
...with zero heat coming out! can anyone give me advice withhow to troubleshoot my heating system. I cant go through another day of this, it must have been like 3 degrees in my blazer this morning driving to work. HELP
btw blazer xtreme 2002 4.3L
Old Jan 17, 2007 | 07:43 PM
blazinwoody's Avatar
blazinwoody is an unknown quantity at this point
Default RE: wow it was cold today here...
So when it was heat did air still blow through? If so then it might be your heater core or maybe your t-stat. I'm sure someone else will have further info to give you
Old Jan 17, 2007 | 07:49 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
The general rule is: figure out the simplest thing that can cause it, and look at that first.
1) Is there coolant in it? (No coolant, no heat transfer)
2) Is it full? (Ditto above, plus low coolant may not circulate through heater)
3) Is there antifreeze in it? (frozen water doesn't circulate or transmit heat)
Start there.
Old Jan 17, 2007 | 09:06 PM
tjbmmb's Avatar
tjbmmb is an unknown quantity at this point
I have a 1998 blazer, what would it mean if it has heat coming out but not as cold as it use to be, and the rad. temp hover above the cold level, and not in the middle like ti use to be. I also put in a new water pump and raditor 4 mos ago.
Old Jan 18, 2007 | 12:13 AM
here is alittle more info: driving to work today i would gun it and warm air would come out then go away. maybe 5 seconds
Old Jan 18, 2007 | 12:37 AM
Chevy Lover's Avatar
Sounds like low coolant in the rad or air in the system. Is the rad full?
Old Jan 18, 2007 | 01:16 AM
rooster's Avatar
rooster is an unknown quantity at this point
flush the heater core, take off the coolant lines and put a hose up to one outlet and watch all the black gunk flow out and then do the same to the other outlet.
Old Jan 18, 2007 | 03:20 AM
20Blazer00's Avatar
yeah sounds like a clogged heater core to me. I should know I have flushed mine twice and the second time i flushed the engine to and changed coolant...now it gets to hot i think i died and went to hell...LoL
Nemo1991
Headers, Intake, & Exhaust
Sep 27, 2010 10:52 AM
sledneck16
Oct 22, 2006 07:02 PM
ivannj
Oct 13, 2006 09:31 PM
strongboy2005
Feb 17, 2006 04:56 PM
ivannj
Feb 11, 2006 03:00 PM
