WTF? Limp mode?
Old Apr 12, 2021 | 01:38 PM
  #21
GeorgeLG's Avatar
Originally Posted by FUN-V
Thanks
waiting for it to cool down a bit then going to do a leak down test, I'm kind of leaning towards fuel pressure regulator, but I need to do the leak down to see that too.
I meant cylinder compression and cylinder leak down test. There is nothing wrong with doing the fuel pressure leak down test but I Don’t think that’s your problem
George
Old Apr 12, 2021 | 01:40 PM
  #22
GeorgeLG's Avatar
I thought negative trim values were bad
you can read my fuel trim article found in my signature. Negative isn’t good or bad. Large numbers are bad. Changing numbers under different conditions help us find the problem
George
Old Apr 12, 2021 | 06:55 PM
  #23
FUN-V's Avatar
FUN-V is on a distinguished road
So, fuel pressure leak down was good, thew the O2s on scope again, and wasn't happy at what I got
Old Apr 12, 2021 | 07:30 PM
  #24
GeorgeLG's Avatar
exhaust restriction from a bad cat can cause your symptoms and running rich can cause a bad cat. What is the decode on those graph colors?
George
Old Apr 12, 2021 | 09:42 PM
  #25
GeorgeLG's Avatar
Do you know how to test for a failed cat?:
Exhaust pressure gauge
Vacuum gauge
Remove O2 sensor
IR gun on cat
George
Old Apr 12, 2021 | 10:28 PM
  #26
FUN-V's Avatar
red and green are the two upstream and the blue is downstream
Old Apr 13, 2021 | 09:36 AM
  #27
GeorgeLG's Avatar
It sure looks like you might have a bad cat. If that is confirmed the question then is why? The biggest causes of premature failure is:
Physical damage
Burning oil
Coolant leak
Unburned fuel (running rich)
Poor quality replacement
You will need to get to the bottom of why your truck is killing cats.
George
Old Apr 13, 2021 | 09:59 AM
  #28
LannyL81's Avatar
Thought I would throw this into the mix.....remove the EGR valve, clean it, and the two small intake holes....look for any small pieces of carbon that could be keeping the EGR valve open.
Also, a question to George...would removing the upstream O2 sensor, then try rev'ing engine, see if it goes past 1400rpm....would this be a valid quick test for a clogged cat? CEL will be set as the O2 sensor reading will be wrong. Can only do this for a few seconds.
Old Apr 13, 2021 | 10:26 AM
  #29
GeorgeLG's Avatar
There are a number of ways to test for a cat induced exhaust restriction. The most conclusive test is to remove an O2 sensor and measure the back pressure at the O2 port. There is also temp measurements, vacuum measurements, tapping on the cat with a mallet, the O2 sensor readings and yes, temporarily creating an exhaust leak by removing an O2 sensor or loosening an exhaust pipe fitting to see if things improve.
George
Old Apr 13, 2021 | 10:59 AM
  #30
GeorgeLG's Avatar
I forget about the EGR valve because my 4.3L does not have one. It’s worth a look.
George
