98-05 S-Series Radio Removal HOW-TO Discussion
Old Jul 4, 2007 | 06:38 PM
drperry's Avatar
Default RE: Jimmy/Blazer Radio removel How To!!!PICS
Good thing I double checked the manual on the wires back there... When I was wiring my switches, I was like "OOOO! Yellow wire! Free power!"
Then I was like... "Waaaaaiiiit a minute... It can't be THAT easy!"
Good write up!
Old Jul 5, 2007 | 11:15 AM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
what is said "yellow wire" for??
Old Jul 5, 2007 | 02:34 PM
drperry's Avatar
Air bags.... Any sort of resistance/voltage change in the wiring of those things and they can go off...
Old Jul 5, 2007 | 02:47 PM
ah. yes that would be very bad lol
Old Jul 5, 2007 | 04:09 PM
drperry's Avatar
According to the Haynes manual, any time you do any kind of work on the wiring or the front of the truck you're supposed to disable the airbags, lol
Old Jul 5, 2007 | 09:33 PM
hillbillyinOhio's Avatar
actually, that yellow wire is just a loom, it contains two 22 or 24 gauge wires (white and yellow) that are your bags!!.. Just reapaired a remote start on a 99 s-10 that the shop that did it thought that was the passlock wires.
Old Jul 6, 2007 | 04:35 AM
drperry's Avatar
Close enough, lol, though, gives me this crazy stupid idea, to wire something in, so when the air bags go off, a loud speaker says "BAM!" or something stupid like that, lol
Old Jul 6, 2007 | 11:04 AM
ChrisAttebery's Avatar
ChrisAttebery is an unknown quantity at this point
Thanks for the pictorial. Your timing couldn't be better. I just bought a Sony CDX-GT610Ui that I want to install next weekend. I've got a Scosche GM1588B dash kit coming and I've got the harness out of my totaled 96 S-10, so I think I'm set to go.
Old Jul 11, 2007 | 09:14 AM
Well, I got my Sony installed last night. I soldered up the connections from the Sony harness to the GM adapter. I think that took the most time, but I prefer solder over crimp connections. The dash went exactly as it was posted here. I had to cut a small piece out of the dash because the Sony was hitting it at the back. The only fly in the ointment is that I forgot to buy a GM antenna adapter. Dohh!!!!
Old Jul 11, 2007 | 10:27 AM
drperry's Avatar
My dash kit is a little bit large for the the opening as well... Luckilly, the dash trim is a little stretchy, lol, and it went over with no problems...
