98-05 S-Series Radio Removal HOW-TO Discussion
Actually, the piece I had to cut was the rear radio support. It was about 1/2" too tall and was hitting the back of the Sony. Once I cut it down the Sony sat flush with the dash.
ORIGINAL: hillbillyinOhio
oh, and btw, you dont need an interface. if you had another harness that went into that black plug, then yes you do. The standard 70-2003 harness will work just fine, and retain the RAP.
But what was this all about if you had the RDS stock HU you have to get a interface to keep the RAP,I still going to use that 70-2003 harness and see if it works.
just ground to the black in the metra harness.
To my quesion in the PM Sent you Rudy,I was just looking at the fuse panel again and saw this
19-radio/batt 15A clarion 15amp
24-radio/ign 10a
Also I know I probly have already talked this to death on the MSN last night with you,But when I use the Fuse tap or acc power I will LOSE the RAP right.I was talking another isntaller today and he said it will still be there IE power windows work but No radio will stay on unless the key is in the Acc/run postion.
This is correct right
