HOW-TO: 4WD Front Hub Replacement - DISCUSSION THREAD
Old Sep 11, 2011 | 05:30 PM
  #31
Kevets's Avatar
Kevets is an unknown quantity at this point
Too late but, yes, BFH and an 18mm. I could get a socket with an extension on mine though with the wheel turned just a bit.
Old Sep 12, 2011 | 05:08 PM
  #32
TheRandom1's Avatar
Good info in this thread. As someone who will be tackling this process in a few weeks, this looks really easy... God I hope it is, at least!
Old Sep 12, 2011 | 06:31 PM
  #33
Kevets's Avatar
Not too bad. Mine came off easier than it went back on though. That was unexpected.
Old Sep 17, 2011 | 11:31 AM
  #34
TheRandom1's Avatar
Have any of you guys that have used the dearbornaxle bearings had any issues so far? I'm interested in buying them since they're so affordable, but if they fall apart quick or something, I'd rather just spend a little more money and get a better set.
I just talked to warthogdriver and it seems he's about ready to have to replace one of them already, so I'm a bit concerned, is why I'm asking.
Old Sep 18, 2011 | 04:43 PM
  #35
robrote's Avatar
robrote is on a distinguished road
I bought my hub/bearing at Summit racing for around 60 bucks. I'v had no issues.
Old Nov 11, 2011 | 06:35 PM
  #36
702Blazer's Avatar
702Blazer is on a distinguished road
ok i know about greasing the back of the breaks and using the anti cease but do I need to grease the bearings at all? Or is it just a bolt up assembly.
Old Nov 12, 2011 | 06:47 AM
  #37
robrote's Avatar
The bearing is pressed into the Hub. It's a sealed bearing so requires no maintenance.
Old Nov 12, 2011 | 07:14 AM
  #38
pettyfog's Avatar
Originally Posted by robrote
You can't get a socket on it. Use an open end wrench and hit it with a BFH (Big hammer), it'll let loose.
Originally Posted by iamchevyman5
is that ^^^ the general consensus everyone???
What is it, about 3/4 inch or what?
Do not use an open end, {That's the 'Best Practices' rule for any first turn situation; open end is always the resort before vise grips} use a box end, six point is best but those are hardened bolts so a snug 12 pt will work fine. Best Practices means rules to go by to avoid grief.
It's the one that fits tight.... though I get it. IIRC, the ones usually left out of sets are 15 and 18.
BFH is a subjective term. Framing hammer is almost always the perfect size.
And yes.. that's one of those things you'll not usually see on videos of professionals doing a job but it works fine.
Old Nov 15, 2011 | 08:58 AM
  #39
eddiep23's Avatar
eddiep23 is on a distinguished road
would it be possible to do manual locking hubs on a 93 s15 jimmy? sure it means extra work to go out and play but it gives me peace of mind to know that its locked on!
Old Nov 15, 2011 | 10:01 AM
  #40
pettyfog's Avatar
That shoulld be on a totally new thread AFTER you do a search on the subject.
blazer. hub lock warn site: blazerforum.com
and
