How-To: EGR Valve Cleaning - DISCUSSION THREAD
My EGR (98 4x4 blazer) didn't have a gasket under it when I unbolted it. Could this have been half my issue? Also, I didn't find a gasket with a screen. So I got one without. Is it that big a deal? Seems like the screen will be one more thing to build up carbon and choke your exhaust.
The screen keeps the carbon from blocking the EGR valve partially open which causes driveability concerns and can eventually damage the EGR valve. If the screen builds up with carbon to the point of blocking off the exhaust supply port, then it would set a code (P0401 - Insufficient EGR Flow), but would not cause driveability concerns unless left this way for a very long time.
A big tx to this thread. It saved me better than $500, when I found out that a stuck pintle on my EGR was causing me to stall out at idle.
I didnt realize that it was so easy to get to the EGR and clean it (+ the screened gasket). W/O threads like this I'd have blown cash on a diag, labor, and replacement EGR.
Wonder if anyone here has seen the code 1404 "Exhaust Gas Rercirculating (EGR) Closed Position" before?
I was told by auto parts that means the EGR valve is bad, especially if I've cleaned the "pintle" valve clean and it retracts fully into the body easily.
HaHa, not so..still getting code error.
I see online a 5 part test system to check each coded wire on the harness, which is my next step, but was wondering if anyone had any hints...thanx.
(this forum has been invaluable in keeping my Blazer going on and on)
Looking to clean both my MAF and EGR at the same time.
Could I use carbon cleaner for both? Could I use the MAF sensor cleaner for the EGR? I do have some brake cleaner laying around...could I use that for the MAF and EGR?
Would appreciate not having a million aerosol cans laying around!
Thanks!
Thanks!
