How to fix rear window actuator. i.e. Rear Window Won't Open
Old Jan 9, 2011 | 04:04 PM
  #61
Brian_D's Avatar
Thanks for this thread.
Can we see the pics?
i cant seem to get them to work.
Thanks!
Old Jan 9, 2011 | 06:09 PM
  #62
rriddle3's Avatar
Thanks!
Already answered in an earlier post in this same thread.
Originally Posted by swartlkk
Known problem with threads from before the change over to vBulletin.
Basically, someone needs to redo this post.
Old Mar 12, 2011 | 03:54 PM
  #63
bigjoe79's Avatar
bigjoe79 is on a distinguished road
Default thanks
I can not tell you how much this helped. Instructions were perfect. Five dollar part from Napa and 15 minutes of my time has my 2001 Blazer working again. Thanks!
Old Mar 13, 2011 | 12:10 AM
  #64
Brian_D's Avatar
The little blue plastic part was broke on mine..
Has been for 5 years.
Today i drilled a hole in it and rigged up a little wire to connect it with the lever.
Works perfect.
Then i went to the salvage yard and snagged the actual plastic peice just encase my easy fix breaks.
But i doubt it will its very sturdy.
i also beat my old bumper into submission and put it back on.
Old Mar 24, 2011 | 02:02 PM
  #65
fedup's Avatar
fedup is on a distinguished road
hey, fedup here. i like this info ,but when i tried to pull back the panel on my 02 it just wont budge .any thoughts? thanks
Old Mar 24, 2011 | 02:38 PM
  #66
There is a screw near the latch that is holding it back. Try locating the hole behind the carpet. If that doesn't work, you have to break the plastic around that screw to be able to pull back on the trim panel.
Old Mar 25, 2011 | 05:55 AM
  #67
mjw644allmand's Avatar
mjw644allmand is on a distinguished road
Default Hang in there Fedup
I too was fed up when I was trying to get my rear glass open and actually drilled a hole through the panel before later finding the factory access hole I noted earlier.
Follow the top of the carpet (assuming your inner panel is like mine) until you get near center - you should feel a depression where the access hole is at then pull the carpet down slightly.
Actuating the manual release through that small hole may not be the easiest to see but it will work.
After getting the glass released you can drop the tailgate and start removing the screws around the perimeter - and don't forget to remove the handle (a couple of screws on the underside of the handle).
Once all the screws are loose you should be able to remove the panel with little force, gain access to the interior of the door and finish this simple fix (it really is once you get the tailgate down).
Hang in there and let me know if you have any more questions....
Old Apr 17, 2011 | 09:24 PM
  #68
jpimp's Avatar
jpimp is on a distinguished road
Originally Posted by rmkenny
Acess release for hatch .
Pictures show acess location and blue broken acuator arm.
Hope this is helpfull to someone. Email questions and I will explain .
Thanks to rmkenny for these pictures, they helped me out a ton!
source:
https://blazerforum.com/forum/2nd-ge...82/#post154020
and the coat hanger works every time.
Old May 24, 2011 | 09:33 AM
  #69
deanhansen's Avatar
deanhansen is on a distinguished road
THANK YOU VERY MUCH! This information helped us fix our rear window actuator in less than 60 mins. Be careful that you do not break the plastic clips when you take off the rear pannel.
DAH
Old Jun 27, 2011 | 12:11 PM
  #70
James Randy Flood's Avatar
James Randy Flood is on a distinguished road
What Pictures?
