How-to: Homemade posi-lock cable system - DISCUSSION THREAD
#45
[QUOTE=swartlkk;306094
Depends on what you have for a transfer case now. I would not attempt this on the 4-button NV236 transfer case. Only on the NV233(NP233) and earlier NP231/NP207 transfer cases.[/QUOTE]
Why wouldn't you try it I have the four button and have been thinking of doing this
#46
I did something very similar with an old boat steering cable worked great for a while until the outer coating on cable took a crap. The way you showed looks waaay better than my job. Nicely done I had issues yesterday and I am going to take your advice and tips to do it better thank you
#49
#50
Did this exact cable install also, with a few changes.
I got the same cable from NAPA, and routed through the cable plug on the passenger firewall by drilling a small hole above that's still tight enough to seal out moisture. The different mounting I did was to come up in front of the coil cover airbox, right behind the overflow reservoir and into the passenger fender. I then kept the bracket original in the same place and used two cable clamps to hold the cable in place routing it through one of the holes for the actuator mounting bolts. I then sacrificed the actuator by taking it apart leaving me only the slotted cylinder that locks onto the bullet shaped diff cable. I then bent the NAPA cable into a three bend 'key' shape and fitted the top of the 'key' shape into the slot where the lock spring locks in the 'bullet' shape cable end fitting and secured it with a pipe clamp. That way if you ever want to sell or whatever you can easily put it back OE and let the buyer enjoy the nightmare this awful vacuum system has been for me. The only problem I'm trying to figure out is finding a metal brace to screw into for the handle as the entire column area appears to be plastic. Thanks for the photos and article-I spent around $35 for everything as opposed to the posilock system that's about the same thing for triple the price! Dodge and Jeep versions send the cable directly to the differential with an aluminum casting cover-while Chevy posilock is tying two cables together without an aluminum cast diff cover but charging the same price! Glad I stopped the order when the $27 freaking shipping charge appeared!
