How-To: T-bar Crank - DISCUSSION
Old Sep 10, 2012 | 02:49 PM
  #141
Front chassis ride height is technically part of a wheel alignment. If you want the alignment done correctly, it must be checked and adjusted if necessary, before adjusting camber, caster and toe. See post #139.
Old Jul 18, 2013 | 06:57 PM
  #142
kwedge243's Avatar
kwedge243 is on a distinguished road
in a nut shell, 4 turns really wont hurt your tucks, yes it will add wear and tear but thats what happens when you lift a truck and put bigger tiers on it... just be prepared to buy some parts every now and again and you'll be fine...
Old Sep 4, 2013 | 07:27 AM
  #143
Blazer2005's Avatar
Blazer2005 is on a distinguished road
I have a 2005 chevy blazer 2dr, what
About after market torsion keys and 2"
leaf springs??? Will I still go threw parts
Quicker even tho the torsion bars are
holding there weight?
Old Sep 4, 2013 | 06:41 PM
  #144
If front chassis ride height is out of spec, (too high or too low) parts will wear prematurely.
Old Feb 15, 2014 | 10:10 AM
  #145
Muddigger86's Avatar
Muddigger86 is on a distinguished road
Not sure of the 2nd generations but the 1st generations front axle/chunk can be lowered a little. If I remember correctly about 1 inch to help with angles on drive line (We used square tubing on the driver side and had to cut and re-weld the right side anchor points lower). We had to lower it a bit to do the V-8 swap on my 85. I then was able to crank the t-bars and get it back to the stock angles and achieve lift at the same time. Basically the same thing that lift companys do to lower the chuck but they do it with fancy brackets.
Old Apr 22, 2016 | 01:24 PM
  #146
Alec Northrup's Avatar
Alec Northrup is on a distinguished road
Nice thread, this helps
Old Nov 17, 2016 | 07:46 PM
  #147
Schrade's Avatar
Schrade is on a distinguished road
Rocking the truck to settle the adjustment I see...
But don't ya' wanna' spray lube in the joints to help out the 'settle', even before wrenchin' the bolts?
Buddykitchen
Dec 10, 2016 06:37 PM
97cherryblazer
Nov 3, 2012 01:08 AM
Sonj
Feb 28, 2012 04:14 PM
g_mike
Aug 22, 2010 02:46 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
