Intake Manifold Gasket Replacement 1996+
Old Feb 10, 2020 | 08:35 AM
LesMyer's Avatar
Default Intake Manifold Gasket Replacement 1996+
I would like to see the following attachment posted in the Tech Section so I can link to it in the future. It's the factory info for 1996+ intake gasket replacement. Includes a step by step with drawings. Also has a section on installing the distributor correctly and torque sequence/values.
File Type: pdf
Old Feb 10, 2020 | 10:25 AM
Where did find this? Is it a GM document?
Old Feb 10, 2020 | 11:26 AM
I would like to submit as a supplement to this the write up I found that now has a dead-link. See attachments 1 of 2 below. (2 of 2 in next post)
Old Feb 10, 2020 | 11:27 AM
Part 2 of 2 attached:
Old Feb 10, 2020 | 12:06 PM
Billy1820's Avatar
Old Feb 10, 2020 | 12:23 PM
From the Tech Article (DIY) Index:
2nd Gen LIM Gasket Replacement by Bruce W. Maki (external link to handymanlyness.com sourced through web.archive.org as handymanlyness.com has since disappeared)
2nd Gen LIM Gasket Replacement by Bruce W. Maki (external link to PDF copy of handymanlyness.com article created from the web.archive.org version in case the web.archive.org copy goes down as well)
These dead links aren't dead and haven't been in months.
I also have the entire page downloaded with plans to recreate it here for preservation, but haven't gotten around to it yet.
Old Feb 10, 2020 | 12:57 PM
LesMyer's Avatar
yes it is
Old Feb 10, 2020 | 01:19 PM
Not dead? I guess it was a while ago the last time I checked.
Old Oct 25, 2020 | 05:38 PM
SilvrHairDevil's Avatar
SilvrHairDevil is on a distinguished road
I'm about to undertake this project with the help of my wrencher guy. Thanks for that LesMyer & Christine_208.
Backstory: Both my SUVs died, the Explorer and the Blazer so I happened upon a mechanic's repo – a '98 Jimmy. I paid top dollar for it 'cause the mech had done a lot of work and ran up costs for parts. I expected more work would be needed and I wasn't surprised.
Now starting the LIM gasket repl and since it's all exposed anyway – the MFI spider seems a natural progression.
I'm a senior and I'm using a “shade tree” mechanic for the work and now I'll be able to monitor him. Anything interesting happens, I'll report back.
Old Oct 25, 2020 | 05:45 PM
Good Luck. There is a lot to get out of the way to get at those LIM gaskets. That is what I remember about doing the job. And as you said, while you are in there, it is worth considering the fuel injector upgrade.
