Water Pump Removal & Install - DISCUSSION THREAD
Old Jan 5, 2011 | 04:03 PM
  #21
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Originally Posted by dagda
The cost of antifreeze was the biggest reason I changed the pump. In the summer I just used filtered water with 20% cheap antifreeze. I don't know how long it would have kept running with leaking pump. As far as expected lifespan for those, my Blazer is a couple hundred miles shy of 250,000, and that's the first thing I've had to change under the hood other than routine maintained (spark plugs etc.) since I bought it in March '07. I don't know if it's the original the casting shows 5077-11 ATF if that means anything to anyone.
250,000? Wow. So these are solid water pumps if that is the original. So you really did have to keep dumping antifreeze into the truck to keep it running.
Now I am glad I have a GM because Lexus wants to replace my mom's water pump at 90 or 100k even though there is no problem with anything on her car but a leaky headlight it and it is a 2008. I guess they have problems with them and/or they want to penalize my mother for their low quality and recalls.
Thanks for the tips. Based on this, I think my pump is fine for now. I will check for a leak later, but since there is no antifreeze on the ground and the levels remain constant, I don't think there is one.
Old Jan 6, 2011 | 12:57 AM
  #22
Ok, I found that hole that you were talking about. No coolant dripping out of it. The area ABOVE it looks damp, but below it (the pulleys and other stuff around it) is dry. I got my fingers under there and didn't get any antifreeze on my hands or anything like that.
Now this is a dumb question: If the pump starts leaking from the hole, isn't it possible to plug the hole to stop the leak? Wouldn't that buy time?
Old Feb 8, 2011 | 06:28 AM
  #23
vandemark.andrew@yahoo.com's Avatar
vandemark.andrew@yahoo.com is on a distinguished road
big problem just changed water pump. and still leaking coolent
Old Feb 8, 2011 | 06:49 AM
  #24
Ok... This is not the appropriate place to ask for help. Please post in the appropriate technical section.
Old Aug 24, 2012 | 07:30 PM
  #25
bluejacket's Avatar
bluejacket is on a distinguished road
Pulled off the water pump tonight and noticed the the threads on one of the bolts is wet, do the bolts need sealer on the threads?
Old Aug 24, 2012 | 07:46 PM
  #26
Jase1979's Avatar
Jase1979 is on a distinguished road
Yes liquid pipe thread sealer should be applied to the bolts on re install
Old Nov 29, 2014 | 08:39 PM
  #27
ndgrown's Avatar
ndgrown is on a distinguished road
is the fan nut reverse threads or normal
Old Nov 30, 2014 | 10:28 AM
  #28
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
The fan is reverse if I remember correctly
Old Dec 1, 2014 | 08:43 PM
  #29
The fan clutch to water pump is right hand threads. Righty tighty, lefty loosy. 36mm open end wrench.
lennyblazer
53
Feb 3, 2016 01:54 PM
TripleBlackBlazer
68
Jun 26, 2012 11:49 PM
Logan
17
Mar 29, 2012 10:59 PM
swartlkk
39
Feb 20, 2010 09:39 PM
