03 Blazer and Avital 4103 Remote Door Locking
Old Mar 16, 2013 | 05:57 PM
OhShhht's Avatar
OhShhht is on a distinguished road
Question 03 Blazer and Avital 4103 Remote Door Locking
Hi,
I know this may be a bit specific of an application but since it seems like a very common remote start unit, someone may know whats wrong.
I replaced a previous remote start unit that stopped working with a Avital 4103 remote start in my 2003 Blazer. I am wondering if anyone knows about the functionality of the lock/unlock feature.
  • Using the previous unit, if you hit lock or unlock on the remote multiple times, the lock/unlock mechanism would work as expected each time.
  • Using the new unit, it will only lock on the first remote lock press. If you hit the button again, the lights will flash but it will not try to lock again. It will only attempt to lock again after clicking unlock first.
  • Unlock works as expected and it will try to unlock the doors each time you hit the remote unlock button.
The installer said that on newer GM cars this is the intended behavior but I know this cannot be the case as the previous unit worked correctly. Can it be a wiring or configuration problem or is this the nature of this remote start unit?
Thank you!
Old Apr 13, 2013 | 07:45 PM
GMJim3687's Avatar
GMJim3687 is on a distinguished road
No the 4103 should be the same as what ever else you had with locking and unlocking. they both NEG triggers for lock and unlock. nothing really fancy with the locking system of a blazer.
wow i missed that one. i read 2000 didnt realize you had an 03. thats a lil bit more involved. but if done correctly you shouldnt have an issue with locking or unlocking the vehicle with the 4103
Old Mar 17, 2014 | 08:23 AM
monette999's Avatar
monette999 is on a distinguished road
hI BLAZER DOOR LOCK HAS A NEGATIVE TRIGGER ?
CAN YOU EXPLAIN THAT?
I thought Blazer has a positve trigger. The Hot orange ist doing to the door swicht?
BR
Bob
Attached Thumbnails 03 Blazer and Avital 4103 Remote Door Locking-clifford.jpg
Old Mar 17, 2014 | 08:49 AM
monette999's Avatar
BR
Bob
richphotos
Jan 23, 2013 04:20 PM
FredEx
17
Nov 3, 2012 01:56 PM
droidxusa
Aug 20, 2012 08:16 PM
Rudolph
Nov 9, 2011 12:08 PM
ComputerNerdBD
Oct 16, 2011 06:10 PM
