1999 S10 Blazer aftermarket stereo problems
Old Aug 12, 2012 | 05:06 PM
Jlewis207's Avatar
Jlewis207 is on a distinguished road
Default 1999 S10 Blazer aftermarket stereo problems
I have an S-10 Blazer that I have replaced the stock Delco stereo in (Model # 09375925). I have replaced it with an aftermarket Pioneer head unit. Everything is wired and working fine with the new head unit, but I do have some questions with the wiring.
Below is an exact mock up of the old connector right off the Delco stereo. Can someone please tell me exactly what each wire does? Granted, I have already hooked up the new stereo, and it is working, but I have some extra wires that have no home, plus I would like to have this information for future use.
Secondly, I do have another problem. After the install of my new Pioneer head unit, my speedometer and odometer have stopped working. They light up, but the needle on the speedometer doesn't move, and the odometer displays mileage, but it doesn't go up.
Any help is greatly appreciated!
Old Aug 13, 2012 | 08:49 PM
Maurer6156's Avatar
Maurer6156 will become famous soon enough
https://blazerforum.com/forum/audio-...l-parts-11284/
And for the speedo and odo check to make sure the wires are connected behind gauges
Old Aug 13, 2012 | 09:29 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
Please tell me you didn't cut the stock harness? If so, WHY?!?! A wire harness is only 10 dollars and I can guarantee, if hooked up properly, you'll have NO problems. If you've cut the stock harness (and I hope you've learned from your mistake) go to the junk yard, get a new harness and pay the damn money to do it right!
Old Aug 14, 2012 | 11:36 AM
the DJ's Avatar
the DJ is on a distinguished road
I found this in my haynes manual:
http://db.tt/CwDB1ZHm
I have the auto volume function on my delco radio so there must be a wire carrying the vss signal going to the radio. Maybe that's your problem with the speedo and the tacho? Vss wire connected to the wrong terminal?
TomCat4680
Oct 12, 2019 01:00 PM
kamilkowalski
Apr 30, 2015 08:36 PM
ddunc71
Mar 14, 2012 12:08 AM
Kaffeene
Apr 23, 2007 04:20 AM
