2000 LS 2 door speaker problem
Hey guys
I've owned my blazer for about 2 years now and ever since I bought it the rear speakers have not worked. Now, more recently the front passenger door speaker cuts in and out. The rear speakers are stock (I've taken the back panels off and looked at them) but I replaced the front door speakers with some used Kenwood's I got from a friend for free. When I bought it, the truck had the factory radio in it as well. I've since then replaced it with an Alpine head unit, but after getting it all wired up the rear speakers still didn't work. This was probably 3 or 4 months ago and I didn't want to mess with anything because of my busy schedule and low income
. Now that I have the time and money, I want to get this problem fixed because I hate only having one speaker working! Has anyone else had this problem? I was reading an older post where someone had a similar problem and he replaced both rear speakers and they worked fine. I think I'm gonna do the same but I just wanted to see if this is common with the Blazers or if I just have crappy luck.
Thanks, Andy
P.S. I'm replacing a bad heater core on Saturday! Wish me luck :/
P.S.S. I'm new to the site but I already love it. I'll be posting some pictures later on.
2000 Blazer LS
2 Door
4x4
130k miles
. Now that I have the time and money, I want to get this problem fixed because I hate only having one speaker working! Has anyone else had this problem? I was reading an older post where someone had a similar problem and he replaced both rear speakers and they worked fine. I think I'm gonna do the same but I just wanted to see if this is common with the Blazers or if I just have crappy luck. Thanks, Andy
2000 Blazer LS
2 Door
4x4
130k miles
it depends. it can be the wiring at the speaker itself or even at the HU, it may even be in between somewhere. IMO when you have the time just re run all your wires, even to the back. thats what i have only cause when i bought mine there was no speakers in it period.
I have had a couple of the factory speakers fail. A way to make sure your head unit is working is to pull it from the dash and hook a small speaker to each output. You should get sound from all 4 outputs. If so, try the same at each speaker location. this will tell you for sure if the speaker is bad or there is a wiring problem.
xJakeLIKEShisBLAZERx
Mar 22, 2014 09:59 AM
c3478493
Feb 3, 2014 02:56 PM
OhioLefty
Dec 21, 2012 12:11 PM
dano440
May 5, 2012 11:32 AM
