4 channel amps
Old Mar 22, 2006 | 04:14 PM
blazinloud's Avatar
Default 4 channel amps
how would i go about powering my 6 speakers with 1 4 channel amp? would the amp have to be 2ohm stable? was looking at the alpine mrp-f240 says 40rms/channel, but im betting my apples its underrated
thnx Adam
Old Mar 22, 2006 | 10:40 PM
corvettecoop's Avatar
corvettecoop is an unknown quantity at this point
Default RE: 4 channel amps
the best way to do this is have an amp that will run 2 ohm stable and if it is a high quality brand the rms should close to double when dropped to 2 ohms from 4. then just have the front 4 run into the 2 channels...as long as they are 4 ohm speakers you'll be set. just make sure you get an amp that will run 2 ohm and retain power for each speaker
another option would be to have the door speakers run of a 4 channel and have the dash run off the head unit. of course the dash wont be as loud as the doors but the only reason they are there is to focus the audio to the front seats. besides most 4x6s cant handle as much power as the 6.5s.
about the amp being underated...a good thing to do would be to go to crutchfield.com and if under the amps specs it says it is "CEA-2006 complient" then the output stated is the true out put. click on the "CEA-2006 complient" inorder to learn more about this.
good luck
Old Mar 23, 2006 | 05:54 AM
blazinloud's Avatar
thanks vette, all newer alpine amps are cea rated, which means the amp will put out at least that much power, every alpine is underrated
mdehoogh
Jan 16, 2008 11:28 PM
nofear17bmx
Nov 30, 2007 09:46 PM
jagblazer01
Jul 20, 2007 05:19 PM
drperry
Jul 13, 2007 03:12 PM
RCarp48
Apr 2, 2007 07:19 PM
