4x6 wiring
Old Dec 26, 2012 | 07:51 PM
bluextremeblazer01slammed's Avatar
bluextremeblazer01slammed is an unknown quantity at this point
Default 4x6 wiring
i am hooking up my amp and i was wondering what the best way to run the wire up to the dash speakers? i have an 01 blazer thanks
Old Dec 26, 2012 | 10:20 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
I'm not 100% sure since I haven't really looked at the wire color on the dash of my Blazer, but, I'd look to see if they're tied into the front door speaker connections at the head unit, if so, just run a wire from there to your amp. I got some Stinger SpeedWire when I did mine, made running wires easy. It's 9 conductor so it has the 8 speaker wires and a wire for the remote.
Old Dec 27, 2012 | 12:13 AM
they are not tied in. i had the bose system and the factory didnt tie them in bc the door speakers were 2 ohm so tying the tweeter in would have made the ohm load two low for the bose amp. I figured someone has done this here. i could tie them together at the hu but i really wanna upgrade the wire to my 61/2s in the door. i guess if i dont get an answer ill run new wire from the 61\2 to the amp, then run wire from behind the hu to the amp and tie them together at the amp.
Old Dec 27, 2012 | 11:07 AM
LeWhite's Avatar
left tweeter is gray/tan. Right tweeter is gray/light green. Gray is negative. Tweeters wired in reverse polarity if aimed to windshield; direct polarity if aimed at driver.
in4lo
Nov 12, 2008 04:11 PM
sifko36
Oct 1, 2008 07:22 PM
Numba1Sean
Apr 22, 2008 04:51 PM
mdehoogh
Dec 20, 2007 05:32 AM
black19
Aug 19, 2006 02:17 PM
