Aftermarket radio
RE: Aftermarket radio
O3Blazer, mind if I ask how you lifted up the rocker panels to route the wiring? Also, did you drill a hole in the firewall, or use an existing one for the power wire? Thanks!
ORIGINAL: vagnozzi
the antenna gromet is above the pass floor area. about where you left foot would be. Pull back the top of the carpet and its right there. adn the kick panels will just pull out. remove the sill panel and then just pull
^ Thank You for simplifying it =)
cool, thanks!
decks have a protect mode? thats news to me......
The Alpine currently in my truck (used to be in my bosses Kia) once said something along the lines of "Hi-Temp" and that stayed on the screen until it cooled down... That could be why the fan squeals when it's cold, and the CD playing portion is iffy... lol
edit: And after checking the manual for my old Alpine CDA-9807 (bought in 2003-ish) it also had the same feature...
I just meant was there a specific way you took off the plastic panels at the bottom of the doors where the floor is. Most of the cars/trucks I've seen have screws that you take off in order to remove the rocker-panel plastic pieces where the door meets teh floor.
ORIGINAL: vagnozzi
thanks, yea, there were only 3 clips holding them down
power wire was easy once you figure out where the grommet is! thanks agian, sorry to stray from your original topic
TomCat4680
10-12-2019 01:00 PM
darkcowboy
07-20-2008 11:30 AM
