Aftermarket radio
Old Mar 27, 2007 | 08:50 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default RE: Aftermarket radio
O3Blazer, mind if I ask how you lifted up the rocker panels to route the wiring? Also, did you drill a hole in the firewall, or use an existing one for the power wire? Thanks!
Old Mar 27, 2007 | 09:26 PM
03blazer's Avatar
03blazer is an unknown quantity at this point
ORIGINAL: vagnozzi
what rocker panels? there is a groomet in the passenger side where your left foot would be. Pull up the plastic piece where u get in at then pull on that kick panel then pull the carpet back and you should see it. it is really big and its where the antenna wire is ran through.
Old Mar 27, 2007 | 09:32 PM
hillbillyinOhio's Avatar
the antenna gromet is above the pass floor area. about where you left foot would be. Pull back the top of the carpet and its right there. adn the kick panels will just pull out. remove the sill panel and then just pull
Old Mar 27, 2007 | 10:53 PM
03blazer's Avatar
^ Thank You for simplifying it =)
Old Mar 28, 2007 | 09:45 AM
vagnozzi's Avatar
cool, thanks!
Old Mar 28, 2007 | 10:48 AM
blazinloud's Avatar
decks have a protect mode? thats news to me......
Old Mar 28, 2007 | 11:14 AM
drperry's Avatar
The Alpine currently in my truck (used to be in my bosses Kia) once said something along the lines of "Hi-Temp" and that stayed on the screen until it cooled down... That could be why the fan squeals when it's cold, and the CD playing portion is iffy... lol
edit: And after checking the manual for my old Alpine CDA-9807 (bought in 2003-ish) it also had the same feature...
Old Mar 28, 2007 | 11:45 AM
vagnozzi's Avatar
I just meant was there a specific way you took off the plastic panels at the bottom of the doors where the floor is. Most of the cars/trucks I've seen have screws that you take off in order to remove the rocker-panel plastic pieces where the door meets teh floor.
Old Mar 28, 2007 | 01:35 PM
03blazer's Avatar
ORIGINAL: vagnozzi
just use a flat head screwdriver to pry up an edge of em and pull up and they will come up easily.
Old Mar 29, 2007 | 02:53 PM
vagnozzi's Avatar
thanks, yea, there were only 3 clips holding them down
power wire was easy once you figure out where the grommet is! thanks agian, sorry to stray from your original topic
TomCat4680
Oct 12, 2019 01:00 PM
98ls
Sep 9, 2010 01:31 PM
2010Tiger
May 12, 2010 06:25 PM
darkcowboy
Jul 20, 2008 11:30 AM
chawkletstarfish
Mar 12, 2005 02:48 PM
