Amp?
Old Jul 8, 2007 | 01:35 AM
DankBlazer's Avatar
DankBlazer is an unknown quantity at this point
Default Amp?
I'm about to buy an alpine type R 10' off of www.onlinecarstereo.com, just not sure if I should get a 4ohm or a 2ohm woofer ( links of the two subs at bottom ), what's the difference or advantage of a 4ohm or 2ohm sub? Also not sure what amp to buy, the sub is only 120$, and i'd like an amp for under $175 that will push this sub nice, would also like to order it from the same place.. well if anyone has some good advice i'm all ears, that is the sub i am getting though, just need some help on an amp what which type R to buy, 4 ohm or 2 ohm, thanks, if i forgot anything i'll add it later
http://www.onlinecarstereo.com/CarAu...roductID=14953
http://www.onlinecarstereo.com/CarAu...roductID=14952
Adding:
Is this a good amp for one type R 10' 2ohm?
http://www.onlinecarstereo.com/CarAu...roductID=16338
[align=left] [/align]
Old Jul 8, 2007 | 11:21 AM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: Amp?
i think that that would be a good setup for good sound
Old Jul 8, 2007 | 04:52 PM
blazinloud's Avatar
Default RE: Amp?
that would work nicely, but i think you'd be better off with a class d amp, built for driving subs......
Old Jul 8, 2007 | 08:56 PM
hillbillyinOhio's Avatar
Default RE: Amp?
not a bad amp. get dual 4's and run at 2 ohms. I agree on getting a class D amp though.
Old Jul 9, 2007 | 02:42 PM
DankBlazer's Avatar
Default RE: Amp?
Do you have any suggestions on amps for just one 10' R?
Old Jul 9, 2007 | 03:03 PM
Default RE: Amp?
Kicker KX400.1, ZX400.1. those come to mind quickly.
JohnBarJB
Sep 28, 2020 07:34 PM
dj00140
Apr 13, 2011 10:40 AM
dougs10
Dec 14, 2010 03:24 PM
bfsmith72549
Nov 1, 2010 05:44 PM
RCarp48
Apr 2, 2007 07:19 PM
