which amp
The biggest problem I have with his and Tony's bench testing is that they don't list or even measure the THD when measuring the power. Sure the amp may have output more than rated power but if the signal was 100% distorted then what's the point? You can't use it like that.
I don't believe there's a readout, could be, but the distortion detection system in the AD-1 amp dyno is the exact same device as the DD-1. As it's used in the amp dyno it's not as horribly inaccurate for that purpose but it's been proven that the DD-1's system of distortion detection has faults. I will admit the AD-1 is a more affordable and reasonably accurate device for measuring amplifier power. However the fact remains that they're still testing the amplifiers output capabilities into a non reactive load which means that once you connect it to the voice coil of a driver those power measurements are immediately skewed. Now, a person will never audibly hear any difference in a few hundred watts of power so it's not like the dyno is completely wrong. The point I'm trying to make is that everyone should take ANY information from such testing with a grain of salt. These results are not real world, exactly what you're going to get when you use that amp in your setup numbers.
There's nothing wrong with using such information when researching and getting informed on the equipment you're looking at but it should never be used as a deciding factor when making a purchase. The real equipment that generates numbers and data that is irrefutable cost many many times what the AD-1 does and there are a lot of good reasons why that is.
Also, I'm not saying Hifonics doesn't make a decent budget oriented product. They do and there's a lot of people using their equipment out there with no problems. Though, it is my opinion that they overcharge for the performance they offer compared to other brands with similar specifications.
But I can see where you are coming from.. I mean, in all reality, testing while listening will produce the best results no matter what, I think anyways.
The way Steve does it is puts it on the amp dyno, there is no audio being played, all it shows is the wattage that the amp is outputting on the dyno, so there is no real way to hear if there is any distortion besides the 4 lights that he has on there...... which got me thinking... I think those lights are for clipping....... I cant be 100% on that at all though.
I am 100% drunk though.
Hey Alton. Can you please get me a box drawn up soon? Guys over on CACO and SMD forum are being a holes -.- and I'm about ready to build this box. Tomorrow if I can get a design from somewhere today..
I drew this up real fast from the dimensions you gave me in other discussions.
It's 3.5cuft NET tuned to 33hz with ~58sqin (3.75" X 15.5") of port area. The enclosure measures 34" W x 17" H x 19.25" D and is about as basic as one gets. If you want to do something any more elaborate such as a double baffle to flush mount the subs or anything like that it wouldn't take much to make those changes. This should do you very well for the SQ212's and most other 12's would be at home in it as well.
Have fun with the new setup!
new question
