Amp gounding question
Old Jan 14, 2012 | 12:38 PM
Steve-o's Avatar
Steve-o will become famous soon enough
Default Amp gounding question
Where is the best place to ground a subwoofer amp ina 96 4door blazer?
Old Jan 15, 2012 | 10:05 AM
altoncustomtech's Avatar
The best place to ground any high current device is where there is sufficient metal to keep up with the current flow, typically the frame of the vehicle. If it's a low powered amp, it's not as critical and anyplace that keeps the ground wire as short as possible will typically be fine. You don't need to drill a hole for the wire to go through the sheet metal either to get to the frame. You can drill a small hole in the sheet metal for a bolt, ground to that inside the vehicle, then outside/underneath run a ground wire from the bolt to the frame.
The MOST important thing to remember is to be sure that the spot where you make any ground connection is as clean as possible of paint, dirt, oils, etc. Also be sure to coat the ground point with a dielectric grease, paint, or anything to keep it from rusting and/or corroding.
Old Jan 16, 2012 | 12:31 AM
Steve-o's Avatar
Thnks for the reminder but the question was really were is the most common other people put there grpund at on thete blazers. But thanks for being active and helping the community
Old Jan 16, 2012 | 01:39 AM
Blazer51's Avatar
Blazer51 is on a distinguished road
I grounded mine on the bolt from the back seats, does its job. I grinded the paint off to get a solid connection metal on metal. i suggest just put it somewhere where it won't get kicked or pulled. Or just add a second battery
Old Jan 18, 2012 | 11:11 AM
illumi-naughty's Avatar
illumi-naughty is on a distinguished road
I hooked up a system in my 96 not to long ago. My amp is behind my back seats, so I just removed the bolts holding the seat down, and ran my ground wire under the seat. It's hidden too. good luck!
Old Jan 18, 2012 | 11:41 AM
Thogert's Avatar
I used the seat bolt too. Just keep in mind that my amp only has ~35w RMS
Old Jan 19, 2012 | 04:33 PM
99bblazer99's Avatar
99bblazer99 is on a distinguished road
idk if yours has it but i have a 99 and in the back there is 4 triangle holder things (idk what there called) but i just took one of those off and sanded around the hole and put my ring terminal on that, then put the whole thing back on top of it. I got it running to 1700w amp and i havent had any problems with it.
Old Sep 28, 2012 | 08:22 AM
Jmes's Avatar
Jmes is on a distinguished road
whether you ground your amp to the chassis or the frame doesnt really differ. i have my amp ground to the triangle hook bolts like 99bblazer99 describes. what really matters is whichever you decide chassis or frame make sure your big 3 upgrade also runs a good neg from battery to chassis or frame and also the engine block needs to be ground to either the chassis or frame. and these blazers have small altenators so i strongly suggest the big 3 upgrade
Old Sep 28, 2012 | 07:55 PM
Maurer6156's Avatar
Maurer6156 will become famous soon enough
Cargo Tie-down points?
Anyway mine is on the seat bolt aswell. Thought about those triangles but the seat one was a little more probably for mine.
JohnBarJB
Sep 28, 2020 07:34 PM
dj00140
Apr 13, 2011 10:40 AM
dougs10
Dec 14, 2010 03:24 PM
bfsmith72549
Nov 1, 2010 05:44 PM
RCarp48
Apr 2, 2007 07:19 PM
