Amp kit to stock stereo?
Old Mar 26, 2011 | 07:09 PM
NCSWP's Avatar
NCSWP is on a distinguished road
Default Amp kit to stock stereo?
That's all I want to know: Can I run an amp kit to my stock head unit/stereo on my 2003 ZR2 Blazer?
Old Mar 26, 2011 | 10:25 PM
jagblazer01's Avatar
I wouldnt do it. Stock speakers arent really meant to handle much power other then that produced by the headunit
Old Mar 27, 2011 | 12:00 AM
blue_zr2's Avatar
blue_zr2 is on a distinguished road
if your talking about hookup up a amp for subs and running a stock radio u need what is called a "line out converter" this will give you your preouts for the rca in able to hook up you amp to the stock radio
Old Mar 27, 2011 | 12:53 PM
NCSWP's Avatar
That's it Blue! Thanks for the help, brother.
Jag, sorry man, guess I wasn't very clear on what I was saying.
Old Mar 27, 2011 | 12:55 PM
NCSWP's Avatar
What do you guys think Best Buy would charge for the kit and install? (900+ watts amp kit)
Old Mar 27, 2011 | 01:00 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
way to much for such an easy install...Do it yourself bro it really is easy as hell.
Old Mar 27, 2011 | 01:07 PM
Benedict1337's Avatar
yea I wouldn't let best buy do it. they charge wayyyyy to much. if you really don't feel confident with doing the install I would check out a local car audio place they won't charge you near as much as best buy.
Old Mar 27, 2011 | 09:51 PM
NCSWP's Avatar
Yeah, I just don't have alot of time is the biggest factor. Where could I find a guide on installing one? What about the line out convertor, what do I do with that?
Old Mar 27, 2011 | 10:05 PM
blue_zr2's Avatar
this will help you out
http://forums.genvibe.com/zerofile/6208/fai.jpg
you can tap it into the back of the radio speaker wires... it taps to the original speaker wires and gives you the preout..
a basic 2-channel LOC has 4 speaker level input wires and 2 line-level RCA outputs. you connect the 4 speaker level input wires to any left/right speaker wires (it doesn't matter if they are front or rear). you will need to figure out which wires are pos/neg; the speaker terminals are often marked, if not then search on google for your car's speaker wire colors (polarity). you will need a set of RCA cables to connect the LOC's line-level outputs to your amp's RCA inputs.
NOTE: if your amp has speaker-level inputs then you don't need an LOC at all. just hook your left/right speaker wires directly up to the amp"s speaker level inputs
LR+ Brown
LR- Yellow
RF- Dark Green
RF+ Light Green
JohnBarJB
Sep 28, 2020 07:34 PM
reapher
Nov 29, 2010 11:56 AM
matt231985
Sep 22, 2009 10:38 AM
JediKnight2
Dec 8, 2007 10:54 AM
Blazer1305
May 31, 2006 03:48 PM
