Amp kit to stock stereo?
if your talking about hookup up a amp for subs and running a stock radio u need what is called a "line out converter" this will give you your preouts for the rca in able to hook up you amp to the stock radio
Jag, sorry man, guess I wasn't very clear on what I was saying.
yea I wouldn't let best buy do it. they charge wayyyyy to much. if you really don't feel confident with doing the install I would check out a local car audio place they won't charge you near as much as best buy.
http://forums.genvibe.com/zerofile/6208/fai.jpg
you can tap it into the back of the radio speaker wires... it taps to the original speaker wires and gives you the preout..
a basic 2-channel LOC has 4 speaker level input wires and 2 line-level RCA outputs. you connect the 4 speaker level input wires to any left/right speaker wires (it doesn't matter if they are front or rear). you will need to figure out which wires are pos/neg; the speaker terminals are often marked, if not then search on google for your car's speaker wire colors (polarity). you will need a set of RCA cables to connect the LOC's line-level outputs to your amp's RCA inputs.
NOTE: if your amp has speaker-level inputs then you don't need an LOC at all. just hook your left/right speaker wires directly up to the amp"s speaker level inputs
LR+ Brown
LR- Yellow
RF- Dark Green
RF+ Light Green
JohnBarJB
Sep 28, 2020 07:34 PM
matt231985
Sep 22, 2009 10:38 AM
