Amp Powerwire and RCA cables
Old Feb 18, 2009 | 04:02 PM
i3lomeh's Avatar
i3lomeh is an unknown quantity at this point
Default Amp Powerwire and RCA cables
I have a 94 4 door s10 blazer, I was wondering if there are any places in the firewall that would be easy to run the powerwire through without drilling. Also, the RCA cable from the back of the head unit. I cant find an easy way to run and hide the cable without taking half the dash apart. Any ideas or suggestions on how anyone run theres
Old Feb 18, 2009 | 05:40 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Default RE: Amp Powerwire and RCA cables
There should be a rubber grommet where the antenna goes through the firewall right behind the passenger side footwell carpet. To attach the RCA cables to the head unit, you're going to have to take the dash bezel off, just like when the CD player was installed.
Old Feb 19, 2009 | 01:16 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
with the deck out of the dash take a straightened out coat hanger and guide it to the bottom of the dash once its through tape your rca on it and pull it back up. Also on your blazer the grommet where the ecm wires go through is big enough to fit a 4awg wire beside the rest of the wires.
Old Feb 19, 2009 | 12:55 PM
BudRacing's Avatar
To be more specific about the grommet... don't take it out and squeeze the cable through the side and leave the grommet half hanging out. If you do, it will leak condensation from your AC accumulator under your carpet and it will start to smell. Take a utility knife and cut a small X into the rubber and push the wire through. You can use some WD40 to make it slide through easier.
Old Feb 20, 2009 | 12:11 AM
mdehoogh's Avatar
ORIGINAL: BudRacing
That explains my constantly damp passenger side floorboard...
Whoops!
Old Feb 20, 2009 | 08:07 PM
i3lomeh's Avatar
I appreciate all the info, but for the life of me I cant find the gromet where the antenna goes. I pulled the deck out and tried to follow it back with my hand but everything is so tight i cant get too it. I also tried starting from the hood but I can reach under the blower motor housing. Any other ideas
Old Feb 21, 2009 | 01:07 AM
cr8390's Avatar
cr8390 is an unknown quantity at this point
ORIGINAL: otnietdehoooo
ORIGINAL: BudRacing
Whoops!
HAHA me 2 now i know whats leaking
Old Feb 25, 2009 | 12:51 PM
BudRacing's Avatar
ORIGINAL: i3lomeh
The easiest way to find it is from inside. It is not behind the dash, it is under it where the carpet curves up the firewall on the passenger side. If you run your hand up to the very top edge of the carpet and pull down you can get to the grommet, however, you'll need to remove the door sill and kick panel to run the wire to the back anyway, so that will make it easier. Just get the carpet up and it should be easy enough to find.
Old Feb 25, 2009 | 04:54 PM
cr8390's Avatar
Just make sure you dont remove the gromet all the way or seal up the hole when your done because i didnt relize it when i did my system not the whole passenger carpet is wet underneath there is even mud under the carpet lol from offroading
Exile
Jul 17, 2011 08:31 PM
CraigSnedeker
Dec 26, 2010 06:20 AM
kennybopaloo
Jun 2, 2010 08:23 AM
Motomatt27
Mar 19, 2010 07:31 PM
tjbmxrider
Mar 20, 2008 09:20 PM
