amp problems
Old 07-30-2007, 03:42 PM
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
Default RE: amp problems
alright so im tryin to find a spot to put my ground. where is a good spot? i have heard you want your ground cable to be under 3ft so where is a good spot to ground to thats in the trunk area?
Old 07-30-2007, 04:47 PM
hillbillyinOhio's Avatar
in our blazers, one of the absolute best grounds is under the drivers side rear seat. lay the back seats down, and lift up that little cover panel. on the side closest to the trim on the drivers side, thereare the seat bolts. there is a bolt right in the middle, a 19mm to be exact, remove that bolt, clean up the metal, and put your ground there.
drperry's Avatar
One of the big nuts under the back seats.
Old 07-30-2007, 04:55 PM
kankoon52's Avatar
alright im gonna have to get a bigger ring to fit around those then. but shouldnt my amp still atleast light up? i hooked everything up the remote cable the rca cords the power cord. i checked the power cord and its getting power.
Old 07-30-2007, 05:02 PM
if there is a bad ground, it will do nothing at all.
Old 07-30-2007, 05:12 PM
kankoon52's Avatar
alright hopefully thats my problem. ill try it and get back to you guys thanks for all the help!
Old 08-01-2007, 10:55 PM
kankoon52's Avatar
alright i grounded it under my rear seat and still nothing. i tried a different amp even and still nothing. i am getting power to the amp but maybe it just isnt enough? im gonna try and re do the connection on my battery tommorow maybe that will help. any other suggestions?
Old 08-01-2007, 11:05 PM
blazinloud's Avatar
try a new rca maybe......
Old 08-02-2007, 01:03 AM
alright, we have ruled out a ground issue for the most part. , now I want you to take a small piece of eire, like 4 inches, strip off both ends,(can even be 18 gauge wire or speaker wire, and make a half circle with it, put one end in the terminal that has battery line to it, and the other end to the remote lead.
that will power on your amp if you do not have a blown fuse, or have a horrible ground. then your problem lies in making sure that you have the remote wire from the alpine deck wired correctly.
Old 08-02-2007, 12:44 PM
blazinloud's Avatar
hey! thats a good little trick, never thought of that.....
Quick Reply: amp problems
