Amp and Sub wiring...will this blow my system?
Old Feb 24, 2007 | 10:09 PM
blazinloud's Avatar
Default RE: Amp and Sub wiring...will this blow my system?
ORIGINAL: RCarp48
I have two subs that seperately have a nominal impedance of dual 4 ohms for one sub. Then I have a Rockford Fosgate amplifier that is 4 ohms. I have my subs wired up to 2 ohms and I was wondering because on my amp I have protect mode and thermal mode. Will my amp go into protect if somethings wrong or will it not because of the wiring?
That was a little confusing lol.......here, I'll get you a wiring diagram...
http://rockfordfosgate.com/rftech/wo...p;woofer_imp=4
you can go 1 ohm or 4 ohms, so you'll wanna go 4.
If you amp is not 2 ohm stable do not run it that low or it will over heat/kick into protect.
Can you at least give us a model #
oh........this should have a seperate thread......if you have more questions.....please start a thread.
1st question is are you sure your amp is not 2 ohm stable?
Old Feb 25, 2007 | 01:47 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
ya its 4 ohm stableI guess.
big94fixup
Feb 21, 2014 07:30 PM
matt92
Mar 21, 2011 02:07 PM
Spartan66
Jul 10, 2008 02:05 PM
dimmuborgir6nik6
Jan 4, 2008 05:06 PM
Canadian88
Nov 14, 2006 05:35 PM
