Amp Woes...SOLVED! Who'da Thought This
Old 11-15-2006, 01:09 PM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
Default Amp Woes...SOLVED! Who'da Thought This
I pulled in to get gas a few weeks ago, stereo working fine. When I started my Blazer back up, the amp never kicked on. I've heard them 'go out' when you start a car, but I heard nothing. The amp is a Kenwood sub amp, 1000 watt. I felt it, it was actually cold. The power is getting through the distribution block, because my x-over was still lit up. The fuse in the d-block was fine, the leads were tight to the power and ground d-blocks. The leads were tight on the amp, and the fuse on the amp was fine. I'm stumped.
Old 11-15-2006, 01:14 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: Amp Woes...never had one do this before...
Power lights? Protect lights?
Any of those on?
This could be bad.............. lol
Old 11-15-2006, 03:58 PM
00blackblazer is an unknown quantity at this point
check it with a test light, also check that your getting power at your remote on wire, and check your ground.
Old 11-15-2006, 04:04 PM
jagblazer01's Avatar
yea take a dmm to it and see if its actually getting power. check the fuses on ur amp if it has external fuses
Old 11-15-2006, 04:56 PM
LunchBox's Avatar
The power light on the amp is not coming on...I checked my ground, but not the remote...I'll try it. I checked the fuse on the amp twice. Oh, the amp has less than 1 year of use on it...BUT, it's been in storage for over 2 years, so no warranty there.
damnit
Old 11-15-2006, 05:12 PM
XBlazer01's Avatar
Try the remote line. Cause it seems like its not getting the 12v signal telling the amp that it needs to power up.
If thats not it post abck up and I'll let ya know a more complicated option
Old 11-15-2006, 05:24 PM
LunchBox's Avatar
ORIGINAL: XBlazer01
Good point...remote wire...mmm...
The more complicated option...does it involve cussing and throwing amplifiers while trying not to break any window glass? 'Cause brother...do I have THAT technique down.
Old 11-15-2006, 05:28 PM
XBlazer01's Avatar
lol It might if theres bad news!
But it'll involve removing the back plate and testing the board's key parts for burnt peices with the DMM
But i think it's the Remote line
Old 11-15-2006, 07:38 PM
x2....check the remote into the amp and into the HU
Old 11-16-2006, 12:51 AM
LunchBox's Avatar
OK...I dunno what "x2", "HU", or "DMM" mean.
Quick Reply: Amp Woes...SOLVED! Who'da Thought This
