another dynamat question
Old Feb 9, 2006 | 04:27 AM
blazinloud's Avatar
Default another dynamat question
Will it be worth it to dynamat the whole front doors (2 door) or can i get away with just a speaker kit which is much more affordable? i will also be putting baffles on them. soon i would like to get the type s comp set and amp them
Old Feb 9, 2006 | 04:49 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
Default RE: another dynamat question
do the whole door. but dont waste your money on dynamat. get second skin, fatmat, or raamat. theyre great deadeners and waaaay cheaper.
Old Feb 9, 2006 | 05:36 AM
blazinloud's Avatar
im in canada and cant say ive ever seen them in store. buying off the net is not an option. any stores here sell those brands? future shop, visions, a&b sound?
Old Feb 9, 2006 | 01:54 PM
catalin's Avatar
catalin is an unknown quantity at this point
No, none of the stores that you mentioned will... You can however find Accumat by Scosche, it's a little cheaper. There's Brown Bread that will work too. Basically anything that will add some mass to the panels will do the job.
Old Feb 9, 2006 | 07:29 PM
FatRyan's Avatar
no no, its more than just adding mass to the panels. The material needs to effectively reflect the frequencies and it also needs to actually stick to the panels very well. i dont know anything about the above mentioned deadeners, but the ones i mentioned are good. im pretty sure that most of these deadeners can only be bought online. Well, i at least know for sure that no places around me sell them. Except the raamat...if im not mistaken that can be found at home improvement stores such as Lowes and Home Depot. And i know u can get a material called Peel'n'Seal at the home improvement stores. Its used for roofing. It pretty much works the same as the others, but its even cheaper. The only problem is that some people have complained of a pretty foul odor coming from it when it sits in a hot car all day. but then again, others have said they smelled nothing at all. and y wont u buy online? its not like u can return the deadener to the store if it doesnt work...
97cherryblazer
Nov 26, 2012 06:13 PM
chrishorton74
Jun 2, 2010 09:03 PM
jagblazer01
Mar 7, 2006 04:17 PM
blazinloud
Feb 16, 2006 08:00 PM
2000ZR2
Dec 11, 2005 01:18 AM
