General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
97' Blazer Help... Battery Draining
Old Jul 20, 2006 | 01:15 AM
BradN10's Avatar
BradN10 is an unknown quantity at this point
Default 97' Blazer Help... Battery Draining
hey guys im having battery draining issues with my 97' Chevy Blazer. My battery keeps draining quickly. I recharge the battery and overnight it's completely dead. i had the battery and alternator tested. the battery test came out good and the alternator test failed. i've installed a new cd player/w speakers recently. also the hitch wires are just hanging there underneath. idk if that could be the cause. but if you need anymore info just let me know. thanks.
Old Jul 20, 2006 | 02:19 AM
Chevy Lover's Avatar
Default RE: 97' Blazer Help... Battery Draining
Welcome to the site!
If your alternater failed, it could have a bad diode in it. A diode is like an electrical flow switch, it allows voltage to flow in one direction and not the other. If the diode fails, voltage can travel in both directions.
If there is a drain on the system, disconnect your under hood lamp, make sure the doors are closed, key is off etc..
Disconnect the negative battery cable ...now touch the cable end to the battery. If there's a spark, there's a battery drain.
Are you fixing this yourself, or taking it somewhere?
If you have tools, there are lots of people on this site that can help with knowledge and advice.
I don't know how much detail to go into regarding diagnosis and repair, til I know what you wanna do.
Let us know, we're happy to help.
Old Jul 22, 2006 | 04:25 PM
BradN10's Avatar
thanks for the reply. well i just replaced the battery and alternater. then i did that test with the fuse taken out for my stereo and no spark. then i put the fuse back in and then there was a small spark. could i have installed the cd player/speakers wrong? thanks.
Old Jul 22, 2006 | 10:58 PM
Which fuse are you using for your stereo? Just asking so I can figure out what else runs off that fuse.
It might be the stereo or any other component that runs off that fuse.
Let us know.
madblazerowner
Apr 28, 2011 06:12 PM
tmay2
Jan 15, 2010 08:52 PM
tnw912
Jan 5, 2010 05:27 PM
brightside
Dec 16, 2009 10:50 AM
kiwiblazer
Oct 21, 2008 01:14 PM
